Prop question for the new boat - SailNet Community
post #1 of 13 Old 04-04-2008 Thread Starter
The warden and I purchased a Pearson 33-2 this fall. It has a Yanmar 2GM engine with a 1" shaft and a fixed 2 blade 16X10 RH prop.
I stumbled across a deal on a used Maratec folding prop but the pitch is 12 instead of 10 would this work with that size Yanmar?. I'm assuming it has a reduction gear.
Sabre66 is offline
post #2 of 13 Old 04-04-2008
It really depends on the boat, engine HP, transmission gearing, and such. IIRC, going up to a 12 pitch, from a 10 pitch, will generally drop your top end RPM by about 500 RPM. It may also cavitate more, as it is a steeper pitch and may slip more. You really need to talk to a prop shop about this IMHO.
óCpt. Mal Reynolds, Serenity (edited)
StillóDON'T READ THAT POST AGAIN.
sailingdog is offline
post #3 of 13 Old 04-04-2008
blt2ski's Avatar
Don't quote me, but some of the folding/feathering props are pitch adjustable. I know my max prop is, but not positive about others. Definetly a call to a shop is in order! And worth it if it will work. The previous and original owner of my boat, gained about 1-1.5 knots switching from a 2 blade fixed to the Max Prop.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #4 of 13 Old 04-04-2008
Valiente's Avatar
I agree: check with a prop shop or the manufacturer. My plastic boat really benefitted under sail with a folder, but there are a few drawbacks as with anything. Google is your friend here.
Valiente is offline
post #5 of 13 Old 04-04-2008 Thread Starter
Originally Posted by Valiente View Post
I agree: check with a prop shop or the manufacturer. My plastic boat really benefited under sail with a folder, but there are a few drawbacks as with anything. Google is your friend here.
Roger that....This is the first inboard I've owned so I'm at the bottom of the learning curve here. SD here are the general specs for the engine.
Continuous rating output Hp/rpm = 16/3400
1-hour rating output. = 18/3600
Reduction ratio forward = 2.21, 2.62, 3.22
Reduction ratio astern.= 3.06
Propeller speed (at cont. rating)
Ahead.= 1540, 1298, 1055
Reverse.= 1113
I will send an e-mail to the manufacturer as well but any info/experience would be appreciated.
John
Sabre66 is offline
post #6 of 13 Old 04-04-2008
Senior Moment
SailorMitch's Avatar
John, also make sure your boat has a 1 inch shaft. My 1988 P-33-2 has a 1 1/8 inch shaft. And yes, best source of info is Martec. I also suggest posting this on the Pearson email list because there are a ton of P-33-2 owners on there.
SailorMitch
Sailing winged keels since 1989.
1.20.09 Bush's last day the end of an error !! Hopefully we still have a constitution and economy left by then.
"Compassion and tolerance are not a sign of weakness, but a sign of strength." The Dalai Lama
good planets are hard to find-- a song by steve forbert
I have but one lamp by which my feet are guided, and that is the lamp of experience. I know no way of judging the future but by the past.-- Patrick Henry.
SailorMitch is offline
post #7 of 13 Old 04-05-2008
blt2ski's Avatar
You probably have the 2.21 reduction, as that is what is behind my 2gm with same general specs as you have. Off the top of my head, I do not remember what size and pitch I have for my boat.
You can find the ratio on the side of the trans IIRC, altho the back upper part is ringing a bell for my setup. Yours may vary a bit.
marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #8 of 13 Old 04-05-2008
I don't discuss my member
Fstbttms's Avatar
The Martec folders are not adjustable.
Fstbttms is offline
post #9 of 13 Old 04-05-2008
trantor12020's Avatar
Sabre66, it would help to first know what the current performance of your engine with this 2blade 16Dx10P prop. What is the max rpm you achieve with this prop. Is it smoking black at max rpm?
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
trantor12020 is offline
post #10 of 13 Old 04-05-2008
I have a 1982 2GM (No F, as it is raw water cooled) Peak 15hp, continuous 13hp.
I assume you have something like a 2GM20 or 2GM20F. Just so you get the right specs!
Northeaster is offline
THE Yacht Builder List T37Chef Boat Review and Purchase Forum 27 10-04-2015 02:38 PM
Re-naming the boat pirateofcapeann General Discussion (sailing related) 130 01-07-2014 12:14 PM
Naming and Renaming Your Boat Sue & Larry Cruising Articles 0 12-15-2003 08:00 PM
Performing in Light Air Brian Hancock Learning to Sail Articles 0 01-15-2003 08:00 PM
Two-Boat Tuning Dean Brenner Racing Articles 0 03-13-2002 08:00 PM
