Which way is the wind flowing??? - Page 2 - SailNet Community
post #11 of 20 Old 04-07-2008
Thanks Courtney.
Originally Posted by Alden68 View Post
You put sheep on your sails??????????
Unless you're from New Zealand, then you put the sailors on the sheep.
hunter Legend 37 Semper Paratus
Formerly - Tartan 34C Yawl
T34C is offline
post #12 of 20 Old 04-08-2008
Once known as Hartley18
Classic30's Avatar
Dock
HAhahahahaha!! Obviously the Kiwi's reputation precedes them!
I have it on good authority that there is now more deer than sheep in NZ. Could be painful for any American sailors planning to visit.
Classic30 is offline
post #13 of 20 Old 04-08-2008
Catalina 38 Avantura
duffer1960's Avatar
Using basic vector math, assuming on a broad reach the angle of the wind is 45 degrees aft of the beam, than any windspeed over 11.31 knots will feel like it's blowing from aft to forward; the faster the windspeed, the higher the forward component of the wind.
Sincerely,
Russ Duff
Catalina 38, Hull #112
"AVANTURA"
Lake Erie
Grosse Ile, Michigan
duffer1960 is offline
post #14 of 20 Old 04-08-2008
Sailor
Plumper's Avatar
On a broad reach the wind will always feel like it is coming from the quarter otherwise it isn't a broad reach! Right? The higher the windspeed the faster the boat but it will still be on a broad reach with the wind over the quarter.
There is a tide in the affairs of men,
Which, taken at the flood, leads on to fortune;
Omitted, all the voyage of their life
Is bound in shallows and in miseries.
Shakespeare, Julius Caesar IV, iii, 217
Plumper is offline
post #15 of 20 Old 04-08-2008
Thanks Courtney.
You are failing to factor in the forward motion of the boat, ie... appearent wind speed. As the true wind speed picks up so will the boats speed, to a point.
T34C is offline
post #16 of 20 Old 04-08-2008
Thanks Courtney.
They had to find a way to accomodate the taller Kiwi's!!!!
Aussie influenced! Lived in WA for a few years.
T34C is offline
post #17 of 20 Old 04-08-2008
Moderator
Jeff_H's Avatar
Assuming a typical boat with a hullspeed of 8 knots (static waterline = 36.6 feet) you could expect the following:
Beam reaching (90 degrees true) 10kts wind true:
Boatspeed- 5 knots, Ap wind- 11.2 kts, Ap Dir 64 degrees off bow
Beam reaching (90 degrees true) 15kts wind true:
Boatspeed- 7 knots, Ap wind- 16.5 kts, Ap Dir 65 degrees off bow
Beam reaching (90 degrees true) 30kts wind:
Boatspeed- 8 knots, Ap wind- 31,1 kts, Ap Dir 75 degrees off bow
Broad reaching (135 degrees true) 10kts wind true:
Boatspeed- 5 knots, Ap wind- 7.3 kts, Ap Dir 106 degrees off bow
Broad reaching (135 degrees true) 15kts wind true:
Boatspeed- 7 knots, Ap wind- 11.2 kts, Ap Dir 109 degrees off bow
Broad reaching (135 degrees true) 30kts wind true:
Boatspeed- 8 knots, Ap wind- 25 kts, Ap Dir 122 degrees off bow
Of course those numbers are dependent on your SA/D and L/D. The boatspeed numbers assume an SA/D around 16-17 and a L/D Under 200. A higher SA/D or lower L/d would yield a higher speed through the water at 10 knots of wind and at the 30 wind range. There would be little impact at the 15 knot range.
And I agree that tying yarn or taping cassette tape to your shrouds at eye level helps provide a sense of the apparent wind direction. You don't need to buy teletales.
Jeff_H is offline
post #18 of 20 Old 04-08-2008
chucklesR's Avatar
That is so sad Jeff, you mean ya'll really only get 5 kts of boat speed out of 10kts of wind on a beam reach?
I get better than 7, more if I fart often.
By 15 kts I'm breaking 10 boat speed on a beam reach, with or without farts.
Polar plot available
On the other hand, in 30 kts I'm cowering in the pilot house with the motor running
chucklesR is offline
post #19 of 20 Old 04-08-2008
Thanks Courtney.
Chucky- You need to give up sailing and buy a jet ski!
T34C is offline
post #20 of 20 Old 04-08-2008
chucklesR's Avatar
No way, too fast for me.
Ironically I have a Crownline 250CR, 43 kts etc.
We hate it. Too fast. It's a 2005 and is for sale, has been since 2005. Take over payments and it's yours.
Many sailboats are faster than mine. Going over 8-9kts makes me nervous, I'm just not used to it yet, plus that whole turtle thing ya know.
Wind Orientation Mark Matthews Learning to Sail Articles 0 03-06-2005 07:00 PM
Charging with Wind Power Kevin Jeffrey Cruising Articles 0 04-21-2003 08:00 PM
Understanding Apparent Wind Steve Colgate Learning to Sail Articles 0 11-10-2002 07:00 PM
Understanding Apparent Wind Steve Colgate Seamanship Articles 0 11-10-2002 07:00 PM
Understanding Apparent Wind Steve Colgate Racing Articles 0 11-10-2002 07:00 PM
