  #1381 (permalink)
Old 03-13-2009
Boasun's Avatar
Boasun will become famous soon enough Boasun will become famous soon enough
The 1st brg is 22.5 degrees off the bow
The 2nd brig is 45 degrees off the bow.
Thus you have the 7/10 rule with those two brgs.
The time difference between the 1st & & 2nd brg is 29 minutes.
S x T / 60 = D or DR to the 2nd brg in this case.
11 x 29' / 60 = 5.3nm
7/10 Rule has the DR X 0.7 = dist to CPA from 2nd brg.
5.3 x 0.7 = 3.7nm
D / S + Time = ETA
3.7 / 11 + 0048 = 0108
or
3.7 / 11 x 60 = 20'
0048 + 20' = 0108
The answer is CPA of 3.7nm @ ETA of 0108
For some people it is easier to do on a Manuevering board...
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
  #1382 (permalink)
Old 03-13-2009
flyingwelshman's Avatar
flyingwelshman will become famous soon enough
5.3 x 0.7 = 3.7nm
D / S + Time = ETA
or
3.7 / 11 x 60 = 20'
0048 + 20' = 0108
Boasun, I am not trying to argue with you - I respect your knowledge and experience. I am new to this and want to learn.
I am confused. I was taught that if the angle of the second bearing is twice the angle of the first bearing, then the CPA is equal to the distance traveled between sightings.
In your example the first bearing is 022.5 and the second is twice that at 045.
We agree on the distance traveled (5.3ish nm), so I don't understand why this rule wouldn't apply.
I don't recall hearing about the '7/10' rule. Would you mind clarifying that for me?
If this has de-railed the trivia thread, I apologize. Perhaps, if you don't mind, Boasun you and I can take this over to PM?
Thanks
1989 Hunter 30'
Southern Georgian Bay
'Nautai te salutamus!'
  #1383 (permalink)
Old 03-13-2009
Boasun's Avatar
You have several rules for various sets of brgs.
7/10 rule is for the 22.5/45 brgs
7/8th rule for 30/60
1.4 rule is for 26.5/45
Plus about 6 other rules in brg sets, including the Natual Cotangent rule.
You can find these rules in either Bowditch or Dutton's or Formulae for the Mariner. There may be other books on navigation that will have them. But the ones I've named are my references for class.
But the easiest way is to use the manuevering board and you needn't worry about which rule to use for distance off. Plotting on a chart works but the MB is the way to go for ease.
Maritime Instructor
S/V Rapture
  #1384 (permalink)
Old 03-25-2009
Boasun's Avatar
Seeing that everyone is totally confused, lets go with something easier:
Where would you find CARLINGS on your boat??
Maritime Instructor
S/V Rapture
  #1385 (permalink)
Old 03-26-2009
nolatom will become famous soon enough
along the centerline, fore and aft, to support the deck?
  #1386 (permalink)
Old 03-26-2009
deberg351 is on a distinguished road
Send a message via Skype™ to deberg351
I am loving this entire thread. I read through the first 30 pages or so, and was content to be in the ballpark with around half the answers. I'll hop in eventually if I'm in the right time and the the right place (and I know the answer).
41' True North, 1980
Boston Harbor
  #1387 (permalink)
Old 03-26-2009
Boasun's Avatar
Sorry NOLATOM, you are warm but not close enough to be even considered in the ball park.
Maritime Instructor
S/V Rapture
  #1388 (permalink)
Old 07-30-2009
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
As we know a caboose is the last car on a train but, where else was it found and what was it used for
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
  #1389 (permalink)
Old 07-30-2009
dacap06 is on a distinguished road
Send a message via Yahoo to dacap06
Hmmm ... I have a fuzzy recollection of a conversation I had as a Midshipman with a mustang LCDR who prided himself on his knowledge of nautical terms and history. He mentioned that a while back a caboose used to refer to the cast iron cooking ranges in the galley, or even to the galley itself. Anyway, how close is that definition to what you had in mind?
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
  #1390 (permalink)
Old 07-30-2009
very close,
Answer: a iron pot on the deck of old whaling ships to boil whale blubber
1978 Tayana 37
Installing an anchor windlass GoodOldBoat Gear and Maintenance Articles 7 02-24-2011 10:22 PM
Bluewater defined? dch Learning to Sail 44 07-29-2009 07:20 PM
The Dollar "crisis" sailaway21 Off Topic 63 12-01-2007 06:25 PM
learning to work on engines? jbarros Gear & Maintenance 5 01-21-2003 04:48 PM
First time in cruising, in mexico, on a 20'' sloop. jbarros Cruising & Liveaboard Forum 7 08-29-2002 09:28 AM
