Blogs
User Name
  #241 (permalink)
Old 04-30-2008
nolatom nolatom is offline
nolatom will become famous soon enough
Right, and right. On a boat, an Irish pennant was something not squared away, or dangling, or not put away right. And the phrase I used to hear was, "Shipshape and Bristol Fashion".
Okay, one of you have to pose a question. I'm tapped out..
  #242 (permalink)
Old 05-01-2008
Hartley18's Avatar
Hartley18 Hartley18 is offline
Blue Heeler
Hartley18 will become famous soon enough
Sway asked "What is precession of the equinoxes?"
I have no idea. (Reminder to self: must buy a sextant one day)
Broker to potential buyer: "Too expensive? Buying a boat is an EMOTIONAL decision - not a financial one!!"
To get the most from Sailnet, follow the link in Craigtoo's signature...
  #243 (permalink)
Old 05-01-2008
Boasun's Avatar
Boasun Boasun is offline
Boasun will become famous soon enoughBoasun will become famous soon enough
This is in reference to the Vernal Equinox that is creeping eastward at about 50" of arc each year.
Sail/Auxiliary Q:
Your 80 ton schooner is hove to on the starboard tack under storm trysail and the fore staysail in 45 knots of wind. Your heading is averaging about 000 true and the wind is from the Northeast. There is a dangerous shoal bearing 270 true, range 5 miles. Which action would be appropriate?
A. You need only stay alert for changes, as your present drift will carry you away from the danger.
B. You should strike all sails and get underway under bare poles, making as much way as possible to the north.
C. You should set a reefed foresail and strike the jib.
D. You should tack or jibe to the port tack and make all possible haeadway to the south.
Go for it Guys & Gals.... and come back with a triva question if you get the correct answer.
  #244 (permalink)
Old 05-01-2008
Plumper's Avatar
Plumper Plumper is offline
Sailor
Plumper is on a distinguished road
A couple key pieces of information are missing. Is the boat making any way and if so, in what direction? How long is the storm predicted to last (is the glass rising or falling)? Where is the boat bound? If it is going north then I would choose A and watch my offing on the reef closely. If I was going south I would choose D. Either A or D would be appropriate if heading east or west.
There is a tide in the affairs of men,
Which, taken at the flood, leads on to fortune;
Omitted, all the voyage of their life
Is bound in shallows and in miseries.
Shakespeare, Julius Caesar IV, iii, 217
  #245 (permalink)
Old 05-01-2008
I'd say D, since port tack will carry you away from the shoal, even if you can't point higher than south (but southeast would be better).
A only works if I'm making headway. If hove-to, maybe I'm not.
B is stupid, unless I have an engine. Do I? Even if I do, striking all sails will give a horrible unsteadied ride.
c--Strike what jib? I 've got a staysail up already.
So I'd get onto the tack that tends to set me away from the shoal rather than towards it.
It's too easy to overthink an answer when they don't give you enough info in the question.
Okay, whether I was right or wrong, since it's May 1st, and easy one..
What's the origin of the distress call "Mayday"?
  #246 (permalink)
Old 05-01-2008
Plumper's Avatar
Sailor
M'aidez! Help me in French.
Which is the preferred end of the start line in a yacht race?
  #247 (permalink)
Old 05-01-2008
If the line's perfectly square to the wind, neither end is favored. Starboard or committee boat end might be preferred if you expect the wind to shift clockwise, and want to be able to tack early.
Otherwise, whichever end is "closer" to the wind. Head straight upwind on the line, and whichever end your bow points more toward is the favored end.
An old one. What's "Sallying ship"?
  #248 (permalink)
Old 05-01-2008
Plumper's Avatar
Sailor
Sallying ship was when the crew would all line up on one side and then run across to the other side to rock the ship. I don't remember why they did it though.
  #249 (permalink)
Old 05-02-2008
Right you are.
It was either to get off ground, or to get out of the ice.
I know I've used a "half-sally" by putting all crew on one side to slide off the mud. I just didn't know what it was called.
Now you have the grave responsibility of posing a new question (and we could then use some new contributors answering and giving us a new question? Don't be shy)
  #250 (permalink)
Old 05-02-2008
Idiens's Avatar
Idiens Idiens is offline
Larus Marinus
Idiens is on a distinguished road
Sallying ship in harbour was used to check its loaded roll stability. The famous case where they broke off the test in panic was the Vasa. It sank in Stockholm harbour a bit later. Too much top weight.
Jonathan-Livingston
Display Modes
vB code is On
Bluewater defined? dch Learning to Sail 41 04-18-2008 02:00 AM
Installing an anchor windlass GoodOldBoat Gear and Maintenance Articles 3 02-10-2008 02:07 AM
The Dollar "crisis" sailaway21 Off Topic 63 12-01-2007 06:25 PM
learning to work on engines? jbarros Gear & Maintenance 5 01-21-2003 04:48 PM
First time in cruising, in mexico, on a 20'' sloop. jbarros Cruising 7 08-29-2002 09:28 AM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
