- Quick Menu
05-12-2008
The most feared catabatic winds that I've heard of are in Greenland (ostensibly the can get over 200Knots {can that be true? Perhaps Km/H?}), where the vast highland plains can generate cold, dry air that only "drains" through a few passes; the winds are called williwaws.
Zanshin - 残心
05-12-2008
Saner (????) Member
Even if it is Km/H, that's a pretty hefty speed! Around 100 mph?
05-12-2008
AdmiralChucklesR
In Tierra del Fuego in South America as well as in Alaska, a wind known as a williwaw is a particular danger to harbouring vessels. It originates in the snow and ice fields of the coastal mountains. Williwaws commonly blow as high as 100 knots, and 200 knot williwaws have been reported.
Interesting read: Rounding the Horn: Being the Story of Williwaws and Windjammers, Drake, Darwin, Murdered Missionaries and Naked Natives--a Deck's-eye View of Cape Horn by Dallas Murphy
05-12-2008
STARBOARD!!! MOVE!!!
Don't think there is an open question out there so here I go
What is the Rule of Twelfths both definition and what is the actual rule
05-12-2008
Saner (????) Member
The way the total tide change is distributed over the tide cycle. i.e., very little change in the hour or so before and after high tide or low tide, and most rapid change midway between high and low. (sorry, that's pretty vague, I think 1/12 in the first 2 hours, 2/12 in the second 2 hours, then 3, 3, 2, 1 and back to slack tide)?
Has anyone gotten Hartley 18's "sewed" question?
05-12-2008
Saner (????) Member
Okay, now that I'm home I was able to look this up - it is 1,2,3,3,2,1, but it's six hours (approx) between high and low tide, not 12 hours. (duh!)
Anyone want to venture a guess what "kumatage" is?
05-12-2008
Depends on whether you're in an area with diurnal or semi-diurnal tides. Some areas only have one high and low tide per day...so twelve hours between tides.
If you're new to the Sailnet Forums... please read this POST.
05-12-2008
Sailor
Regardless of the time between tides, the rule of twelfths applies. Just divide the time between tides by 6 and apply the rule of twelfths. Works for Diurnal, semi diurnal and mixed tides.
There is a tide in the affairs of men,
Which, taken at the flood, leads on to fortune;
Omitted, all the voyage of their life
Is bound in shallows and in miseries.
Shakespeare, Julius Caesar IV, iii, 217
05-12-2008
gadfly
Just to clean up-the mistral is a cold, dry wind from the NW in the Tyrrhenian Sea that flows down off the Alps. The Sirocco is it's counterpart from the south or SE, mostly in the summer, off the Sahara. Pardon the interruption.
05-12-2008
Blue Heeler
Nope - it got lost in the wind back there somewhere!
Since it's related to the current (pun intended) discussion I'll give you the answer: If you're "sewed", you've been left high and dry on a mud flat.
It's a British term - so probably not fair on you lot.
Broker to potential buyer: "Too expensive? Buying a boat is an EMOTIONAL decision - not a financial one!!"
To get the most from Sailnet, follow the link in Craigtoo's signature...
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
