04-20-2008
Heavy on the Mr. part
Good idea methinks
I think you are actually on the right track for a couple of different reasons.
First is that if you build this thing you will get pretty familiar with wood work, epoxy, and fiberglass work.
You will learn basics such as tabbing to a hull, making a nice fillet, how to properly laminate wood and FG to make a very strong composite, getting the right amount of epoxy in the glass etc.
This in my opinion is going to make it easier when you walk up to that 35' boat you plan on buying and when you see a repair or change that needs to be make you already have a good idea what it would take to fix it, how difficult it will be, if it is something you can handle or have to hire out.
When you see delaminated/ crushed/ cracked fiberglass around the companionway sliding hatch you know it is/is not going to be a bear to fix, you know right then to tell the owner "hey that is going to cost me a lot to fix and take quite a bit of work to get it fixed so it won't leak!"
learning things like that, or just the knowledge that you don't really like working with that kind of stuff after all! Which leads you to the realization that you would be better off looking for a somewhat newer boat.
I really don't see a downside except what you build may end up not fitting what you end up buying. But maybe the experience is worth it, and perhaps you can sell it for enough to cover most of a walker bay Plasti-bote!
FYI there are a lot of designs out there which you can build that will use 1 sheet of 1/4" plywood. So the wood cost is pretty cheap, it is the epoxy that runs up the price and weight. Good luck whatever you decide.
LuckyTexan
