Blogs
User Name
  #41 (permalink)
Old 1 Week Ago
LarryandSusanMacDonald's Avatar
LarryandSusanMacDonald LarryandSusanMacDonald is offline
SaltwaterSuzi/CapnLarry
LarryandSusanMacDonald will become famous soon enough
Here's one that makes sense once you think about it:
If you've got dorade vents with two in front and two in back, when the boat is unattended (or just closed up) turn the back two to face aft. That way the breeze comes in one set and out the other.
With them all set in the same direction, very little air flow results and mildew will gitcha.
Saltwater Suzi and Cap'n Larry
Boat maintenance axiom: The splash you just heard was from an irreplaceable part.
  #42 (permalink)
Old 1 Week Ago
TrueBlue's Avatar
TrueBlue TrueBlue is offline
Señor Member
TrueBlue has a spectacular aura aboutTrueBlue has a spectacular aura about
On that same theme, it makes sense with just two adjacent dorades, to have them facing opposite directions - but, parallel with prevailing winds.
True Blue . . .
sold the Nauticat
  #43 (permalink)
Old 5 Days Ago
T37SOLARE's Avatar
T37SOLARE T37SOLARE is offline
Tartan 37C
T37SOLARE is on a distinguished road
This is a great thread, so to revive it I'll add this for un-winterizing your fresh water system:
Last year it seemed like I still had traces of antifreeze in the fresh water system until August, so this is what I did yesterday to make sure it was fully purged.
Get a barbed female garden hose fitting that fits your freshwater plumbing tubing (Mine is 5/8")
Remove the tubing from the output side of your freshwater pump, and insert the garden fitting.
Put a shutoff valve on the end of your garden hose
Connect the hose to the fitting you put on the supply line in the boat.
Open all faucets, and slowly open the valve to the desired flow and let it run until all traces of antifreeze have been flushed out. I ran it for 30-45 minutes.
This eliminated allot of wear & tear on the fresh water pump, and ensured that the system was clean.
For the water tanks, I disconnected the supply line in the bilge, and filled and flushed the tanks several times.
http://www.sailnet.com/forums/image.php?type=sigpic&userid=147496&dateline=12050  32520
SOLARE
T-37 #442
  #44 (permalink)
Old 5 Days Ago
dongreerps dongreerps is offline
dongreerps is on a distinguished road
dirty eyeglasses
When your glasses get dirty, or fouled up with dried on salt spray, to clean them, first spray with spray was (Lemon Pledge), and then polish them as usual. Gets all the crud right off. Also the wax fills in all the microscopic scratches in the lenses, so the lenses are restored to their original curvature!
  #45 (permalink)
Old 5 Days Ago
holes in tennis balls
The suggestion on use of tennis balls is clever. In order to drill the hole in the tennis ball, drill a hole 3/4 the size of the tennis ball in a block of scrap wood. Put the tennis ball in the hole, and then drill the hole in the ball.
  #46 (permalink)
Old 4 Days Ago
svstrider svstrider is offline
svstrider is on a distinguished road
Other uses for clothes pegs
If I am trailing a fishing line or anything for that matter e.g. the wife, I put a plastic clothes peg (red is best) on the engine throttle lever to remind me that something needs to be done before starting the engine - like retrieve the fishing line or the wife. Well definitely the fishing line.
  #47 (permalink)
Old 4 Days Ago
Remove engine key before doing prop work
I remove the engine key/s (I own a cat) if I am going over the side to work in the water. Just in case someone has a brain snap and decides to start up the donks. Very important strategy if there are kids or drunks on board. I put the keys in the beer fridge to remind ME to have a cleansing ale when I return from underwater maintenance in exotic locations.
I DO trust the wife but if I know the keys are not inserted, I don't have nagging scarey thoughts about being made into chopped liver. I have enough to worry about with sharks and salt water crocodiles as it is.
Last edited by svstrider : 4 Days Ago at 05:14 AM. Reason: lousy grammar & missing words
  #48 (permalink)
Old 4 Days Ago
chucklesR's Avatar
chucklesR chucklesR is offline
Gemini 105Mc Hull 987
chucklesR has a spectacular aura aboutchucklesR has a spectacular aura about
I have a RIB as a dinghy, and store it on davits. Since you don't want the boat to fill with rain water and rip said davits from the hull one normally pulls the drain plug on the dinghy after raising it. After more than one time of lowering the dinghy without first re-installing the plug (makes for a little fun doing a quick rehoist) I started thinking.
After I took some aspirin to clear up the headache that caused I took a piece of sting and tied the plug to the cleat on the davits, on the side the engine/plug goes.I can't uncleat the line and lower the dinghy without untying the plug which is a wonderful reminder. Now I can't loose the plug, or the dinghy
  #49 (permalink)
Old 4 Days Ago
sailingdog sailingdog is offline
sailingdog has a spectacular aura aboutsailingdog has a spectacular aura aboutsailingdog has a spectacular aura about
Chuckles-
I hear thinking is hazardous to your health...wears out the brain cells.
—Captain Malcolm Reynolds, Serenity (slightly edited)
If you're new to the Sailnet Forums... please read this POST.
  #50 (permalink)
Old 4 Days Ago
chucklesR's Avatar
Everything other than Rum is hazardous to my health.
Display Modes
vB code is On
Need marina tips on the eastcoast Iggy Cruising 15 3 Weeks Ago 06:44 PM
How do you fund your sailing... Hints, tips, just frugal? JodyKS General Discussion (sailing related) 91 04-16-2007 11:37 AM
First Greek charter, looking for hints... Req Chartering 9 11-22-2004 01:40 AM
Need Tips on Interior Mold RNicholson Gear & Maintenance 11 06-25-2002 08:10 PM
The Best Tips from Women Aboard Kathy Barron Gear and Maintenance Articles 0 10-13-2000 08:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
