  #31
Old 05-02-2008
Jeff_H's Avatar
Administrator
Jeff_H has a spectacular aura about Jeff_H has a spectacular aura about Jeff_H has a spectacular aura about
"Witzgall - the forward hatch in the picture is going to break or develop a severe leak quickly."
Well there's a statement that i completely disagree with. The majority of production boats have their forward hatches mounted with the hinges aft and they rarely, if ever have a problem. The dog side of the hatch (vs hinge side) usually has the better seal since the dogs compress the gasket making a forward facing hatch more watertight when hit with green water (half blue-half yellow) when closed. An open forward hatch will catch jibsheets whichever way it faces.
In terms of ventilation, I had a boat which had a forward hatch that could open either way (you shifted the hinge pins) and it clearly had better ventilation when opened to the rear. There is a theory of ventilation that suggests that the area of the exhaust end of a non-compressed ventilation system should have 50% more area than the intake end. On my boat the forward hatch has its hinges facing aft (opening facing forward) and the main cabintop mounted hatch has its hinges facing forward (opening facing aft) which when combined with the area of the companionway seems to be consistent with that theory.
I do leave the midships hatch with the forward hinges open when sailing in moderate or less conditions and it does not seem to take spray down below.
  #32
Old 05-02-2008
witzgall is on a distinguished road
So one more question - What kind of goo should I use to seal the flange to the deck?Lewmar specifies a sealant, as opposed to an adhesive, but they don't go as far as to recommend a particular one.
Jubilee
1985 Wauquiez Pretorien
You may post attachments
You may edit your posts
Hatch Leeks and Rebedding of Hatches pmesmer General Discussion (sailing related) 7 03-20-2008 08:27 AM
Have you driven backwards? deniseO30 herSailNet 17 10-06-2007 04:20 AM
leaking deck hatches dougshipl Gear & Maintenance 6 07-31-2007 12:58 PM
Replacement Hatches for Valiant 40 Shahrazad Gear & Maintenance 0 02-09-2005 04:47 PM
Resolving Hatch and Portlight Problems Tom Wood Gear and Maintenance Articles 0 03-17-2003 07:00 PM
SEO by vBSEO 3.6.1
