05-09-2008
Actually, the way I read that is that the dinghy can't have an engine of greater than 10 HP... I don't believe it is written to exclude sail-powered or human-powered craft... just to limit the size of the engine that can be on a tender. Sails are less than 10 HP, as are oars.
Originally Posted by hphoen
Good point! I'd use that excuse, too, if pulled over!
I thought I remebered reading about this, and I tracked it down. John Pollard has done all the research. Snip from his post in a different thread,
http://www.sailnet.com/forums/genera...istration.html
As a follow-up to my previous post, this is what it says in the FAQ section of the USCG Vessel Documentation Center:
IS THE VESSEL TENDER DOCUMENTED?
Documentation of your vessel does not cover the vessel's tender or dinghy. These craft fall within the jurisdiction of the motorboat numbering laws of the state of principal use. Please contact your state agency that handles the registration or numbering of motorboats for further information. |
HOWEVER, this is what the Code of Federal Regulations at Title 33: Navigation and Navigable Waters, has to say:
§ 173.13 Exemptions.
Where the Coast Guard issues numbers, the following classes of vessels are exempt, under Section 12303 of Title 46, United States Code, from the numbering provisions of Sections 12301 and 12302 of Title 46, United States Code, and this part:
(a) A vessel that is used exclusively for racing.
(b) A vessel equipped with propulsion machinery of less than 10 horsepower that:
(1) Is owned by the owner of a vessel for which a valid certificate of number has been issued;
(2) Displays the number of that numbered vessel followed by the suffix “1” in the manner prescribed in §173.27; and
(3) Is used as a tender for direct transportation between that vessel and the shore and for no other purpose. |
So the exemption, if it exists at all (??) would only apply to a motorized dinghy of less than 10hp.
