Denby-
Depends on the line.
It really depends more on the sheave.
If the wire is spliced to the
line. And if the splice passes over the sheave. Then the sheave is probably a Rope/Wire sheave.
If the splice doesn't pass over the sheave then it's probably a wire sheave and someone wasted their time doing a rope/wire splice. They could have just Nico-pressed a thimble and tied the
line. (External) That would be a lot simpler and less expensive than the splice
If the topping lift is internal and the sheave is made for rope only then there was no need for a rope/wire splice at all.
That doesn't mean that someone didn't find a good deal on a rope/wire halyard and use it instead of just a piece of rope but who knows. Could happen
