Blogs
User Name
  #61 (permalink)
Old 05-14-2008
Insails Insails is offline
Insails is on a distinguished road
My boat has no topping lift. So I spend a little extra time tweaking the sail with the boom vang. Never forget to hook the boom to the cable on the back stay or you get a lap full of boom when you haul in.)
  #62 (permalink)
Old 05-14-2008
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
If you want redundancy, go with the same diameter as your main halyard. If you want to reduce windage and weight aloft... and don't need/want the redundancy, go with 5/16" or 1/4" line.
—Captain Malcolm Reynolds, Serenity (slightly edited)
If you're new to the Sailnet Forums... please read this POST.
  #63 (permalink)
Old 05-14-2008
Hartley18's Avatar
Hartley18 Hartley18 is offline
Blue Heeler
Hartley18 will become famous soon enough
Originally Posted by denby View Post
I disconnect the topping lift when the sail is up, it interferes with the sail.
'kay. Each to their own. Many people prefer to know that there is something holding the boom up should the halyard let go - or you need to reef in a blow. Getting to the end of the boom can sometimes be a life-threatening experience!!
What size in diameter line?
I'd suggest the same diameter as your halyards - but in stretch, not stiff.
If you select the same trace colour as your main halyard, that can help with finding the tail again at the end of the day!
Broker to potential buyer: "Buying a boat is an EMOTIONAL decision - not a financial one!!"
To get the most from Sailnet, follow the link in Craigtoo's signature...
  #64 (permalink)
Old 05-14-2008
brak brak is offline
Sea Slacker
brak is on a distinguished road
I used to disconnect the topping lift on one of my first boats, until one day I forgot to reconnect it before dropping the sail. Ended up riding back into the slip with the boom in the cockpit looking pretty darn silly too. From then on, topping lift stays in place.
  #65 (permalink)
Old 05-14-2008
denby's Avatar
denby denby is offline
Location: Dead Sea, some times called Long Island Sound
denby is a jewel in the roughdenby is a jewel in the roughdenby is a jewel in the rough
The problem with keeping the topping lift connected is the main about half way up over laps the topping lift about 6 inches. The main is full batten, if I'm on the same tack all day no problem, big problem when tacking.
Dennis
O'Day 302
Be careful or i will do what the voices tell me to do
To get the most from Sailnet, follow the link in Hartley18.'s signature.
  #66 (permalink)
Old 05-14-2008
Stillraining's Avatar
Stillraining Stillraining is offline
Stillraining has a spectacular aura aboutStillraining has a spectacular aura aboutStillraining has a spectacular aura about
Denby;
IMHO...If your origional is 3/8 I would stay with that size, your shiv is made for it...It has a tensile strength of 4400 lbs in Sta-set...I would not hesitate to go aloft on it if needed..
  #67 (permalink)
Old 05-14-2008
Denby-
Just leave it connected, but slacken off on it...then it isn't a problem. That's what I do.
  #68 (permalink)
Old 05-14-2008
Hartley18's Avatar
Blue Heeler
..but don't slacken it off too much - that's when it gets wrapped around spreaders.
  #69 (permalink)
Old 05-14-2008
denby's Avatar
Denby-
Tried that but it gets tangled in the back stay. Maybe with line it might be different.
Dennis
O'Day 302
  #70 (permalink)
Old 05-14-2008
Hartley18's Avatar
Blue Heeler
With a single run of line, you'll have even weight all the way down so it should be easier to control than the crazy rope/wire set-up you have now.
...and even if it does wrap round the backstay, it should unwrap pretty quickly.
Display Modes
vB code is On
topping lift wumhenry Learning to Sail 24 08-04-2007 02:19 PM
Topping Lift jkrug Gear & Maintenance 18 05-04-2007 09:07 PM
Topping lift PBzeer Seamanship 11 02-19-2004 07:39 PM
hard vang means no topping lift? jbarros Gear & Maintenance 14 07-11-2003 08:43 PM
Topping Lift sehopkins Learning to Sail 4 07-24-2001 07:02 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
