Blogs
User Name
  #11 (permalink)
Old 05-13-2008
Rockter Rockter is offline
Rockter is on a distinguished road
These accidents are an inherent problem with gasoline in an enclosed space.
A vapour detector in the bilge with an ignition cut-out?
Yea right.
A rough day, returning home against a chop, in a channel, in a current, rocks around, a rising crosswind, and needing the motor. The detector will then decide to cut out, for whatever reason. You will feel so much safer when it does.
  #12 (permalink)
Old 05-13-2008
Jeff_H's Avatar
Jeff_H Jeff_H is offline
Moderator
Jeff_H will become famous soon enough
That is a tragic story. It would be interesting to hear what the enquiry discovers.
I'm not sure how relevant this explosion is to gasloine powered sailboats. It is odd but in my lifetime I have personally heard of probably a couple dozen sailboats that exploded and except for one particularly eggregous case, all were propane explosions on boats with diesel engines. On the other hand, most of the powerboats that I have heard of that exploded have been gasoline engined.
The problem with carrying propane on a boat is that the boat should have a bilge blower, and explosion proof alternators, startes and electrical systems, just like a boat with gasoline on board, but they don't. Folks with gasoline engines usually understand the need to take proper precautions before firing up the engine, but people with propane systems often take them for granted.
  #13 (permalink)
Old 05-13-2008
tweitz tweitz is offline
tweitz is on a distinguished road
Were any of those propane explosions in a boat with a properly ventilated outside storage locker? Most of the ones I have heard of were on boats with propane added on post-builder, and the tanks were not in compartments properly drained overboard. I have also always been a fanatic about shutting off the manual valve on the tank whenever the propane is not in actual use.
Sponsored Ad
  #14 (permalink)
Old 05-13-2008
TrueBlue's Avatar
TrueBlue TrueBlue is offline
Seņor Member
TrueBlue is a jewel in the roughTrueBlue is a jewel in the roughTrueBlue is a jewel in the rough
tweitz,
Modern propane onboard systems, if installed according to ABYC standards, are a safe and extremely convenient means for cooking and heating. The fact that most cruising boats today have them says much to the industry and public's acceptance.
Stating otherwise is analogous to blanketing all natural gas and LPG home installations as being unsafe. I had it in my last boat and will choose to have it in the next.
True Blue . . .
sold the Nauticat
  #15 (permalink)
Old 05-13-2008
SEMIJim's Avatar
SEMIJim SEMIJim is offline
Nautical Newbie
SEMIJim will become famous soon enough
Originally Posted by chucklesR View Post
My understanding is that's one gallon = 20 sticks.
"When mixed with air in the right proportions, the vapor of one cup of gasoline has the explosive power of about five pounds of dynamite, enough destructive force to destroy any house or car." Ref: NASD: Storing Gasoline and Other Flammables
I don't know how many sticks of dynamite it takes to get up to five pounds, but five pounds seems like a lot of dynamite to me!
Jim
"If fifty million people say a stupid thing, it is still a stupid thing." - Anatole France
1976 Pearson P30 #914 - s/v Abracadabra
  #16 (permalink)
Old 05-13-2008
Zanshin's Avatar
Zanshin Zanshin is offline
Zanshin is on a distinguished road
The gasoline would have to be fully evaporated and perfectly mixed with air to generate that kind of force - and the comparison with dynamite is only fair comparing the volume of expansion gases generated but not the speed at which it happens. Gas ignites/deflagrates while Dynamite detonates and will create a pressure front/wave. Gasoline vapor will blow up a boat but can't cut down a telephone pole.
For the curious - most mining doesn't use dynamite as it is too expensive. They use something called ANFO which is basically diesel and Ammonium Nitrate (fertilizer).
Zanshin - 残心
  #17 (permalink)
Old 05-13-2008
TrueBlue's Avatar
Seņor Member
Fertilizer bombs - otherwise known as IEDs (Improvised Explosive Device).
True Blue . . .
sold the Nauticat
  #18 (permalink)
Old 05-13-2008
nolatom nolatom is offline
nolatom will become famous soon enough
What a horrible thing to happen to the people, and to a lovely old boat. Just awful. I grew up with gasoline engines (mostly the Utility Four, the Atomic Four, and a few Kermaths and Graymarines and some other antiques) and respected the danger, but wasn't paranoid about it. Nothing bad ever happened, but I thought the best vapor detection system was the human nose, down low in the bilge.
I agree with those above who've said that the real danger isn't at the dock, when you have time and quiet seas to delay ignition and sniff the bilge and run the blower, but later on when you need the engine unexpectedly and just hit the ignition without thinking about vapor accumulation.
Gasoline, when I was a kid, was the smell of something good about to happen. Trouble is, in a very few instances it was the smell of something really bad about to happen.
While this was terrible, and I like all you Aussies, I think the tendency to overreact and over-regulate is even stronger there than in the States, if that's possible..
  #19 (permalink)
Old 05-13-2008
r2k815 r2k815 is offline
r2k815 is on a distinguished road
The explosive force of a solvent vapor cloud explosion comes from confinement of the vapor. Without confinement, with a simple vapor cloud in air, you have a flash fire. With confinement, such as vapors in an engine compartment or bilge, you have an explosion. Any flammable liquid, gasoline, acetone, paint thinner, starting ether, etc., has the potential for a vapor cloud event under the right (or wrong) circumstances.
  #20 (permalink)
Old 05-13-2008
Hartley18's Avatar
Hartley18 Hartley18 is offline
Blue Heeler
Hartley18 will become famous soon enough
It's quite incredible to me that someone could buy an old well-maintained boat, put their nearest and dearest on it, follow all the correct procedures for fuelling (including waiting 5 minutes or so afterwards) and then blow it all sky-high. It was really not his day...
Perhaps he did put fuel in the wrong tank - it's possible I suppose - but there were no reports of fuel smell at the time so everyone's assuming it was something in the engine compartment.
Ahhh... yes. The authorities here have a habit of running around in circles clockwise for a bit, and then unwinding themselves in the other direction, then actually thinking about it... and then forgetting what it was they were going to do. I think it's inherited from the US of A from watching too many of your stupid TV shows...
The guy that runs the restaurant is a good friend of one of my work collegues and was the first on the scene. He said the guy was a blithering mess (as you'd expect) and now has to get his life back together.
Personally, I hope the authorities forget about it. Stuff happens.
Cameron
Broker to potential buyer: "Too expensive? Buying a boat is an EMOTIONAL decision - not a financial one!!"
To get the most from Sailnet, follow the link in Craigtoo's signature...
Display Modes
vB code is On
Sail Vs Powerboats? ImASonOfaSailor General Discussion (sailing related) 63 03-19-2008 07:04 PM
Sailboat cost vs Powerboats Fishboat Buying a Boat 15 03-13-2007 09:50 AM
Exploding tyre sends mechanics flying (Independent Online) NewsReader News Feeds 0 02-14-2007 03:15 AM
Powerboats hit the water today in Classic - Port Huron Times Herald NewsReader News Feeds 0 07-30-2006 10:15 AM
Rules of the Road John Rousmaniere Her Sailnet Articles 0 12-28-2003 08:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
