Blogs
User Name
  #11 (permalink)
Old 05-14-2008
MedSailor's Avatar
MedSailor MedSailor is offline
"Fairhaven" Formosa 41
MedSailor is on a distinguished road
If you want to know all about the latest survival equipment and about liferafts go to Doug Ritter's EQUIPPED TO SURVIVE - Outdoors Gear, Survival Equipment Review & Survival Information
FANTASTIC site. He even designed and ran a liferaft test which caused many liferaft designers to make major changes. Links to equipment, real stories, and good, unbiased reviews.
If you find his site useful please consider a small donation or including it in the credits of your book. I've been watching his site for 10 years and it has actually saved people's lives though Mr. Ritter doesn't break even running it.
MedSailor
"True, your boat will outperform mine to windward, but my boat will always outperform yours at anchor." --MedSailor
  #12 (permalink)
Old 05-14-2008
sailaway21 sailaway21 is offline
gadfly
sailaway21 is a jewel in the roughsailaway21 is a jewel in the roughsailaway21 is a jewel in the roughsailaway21 is a jewel in the rough
bajagirl,
You might find some helpful info here: Switlik Search & Rescue Life Raft
The most desirable raft is one mounted on deck in a fiberglas canister and it is held down by metal bands that have a hydrostatic release. The hydrostatic release is designed to operate at 15' submergence. It has a plunger button on it's face which can be slapped in, usually with a kick from your foot, that will release the raft from it's cradle to be thrown overboard manually. (I know this isn't in your storyline) There is a lanyard that is secured to a padeye on deck that, as the vessel sinks, is pulled out of the raft and, when tensioned, inflates the raft. The lanyard, where it secures to the padeye, has a breakaway link that is sufficient to pull out the lanyard to inflate the raft but will part before the raft is dragged under by the sinking vessel. These rafts also come alternatively stowed in a valise for below decks stowage. To launch either manually you secure the lanyard on deck and then push the raft over the side. Once overboard you pull on the lanyard until all slack is out of it and then give a good yank to inflate.
The raft has ballast pockets on the bottom that capture seawater within them and help to keep it upright. The raft can inflate in any position but will usually inflate upright. Once the ballast pockets have filled it will usually stay upright. There is a lifeline of polypropylene line that circles the raft for swimmers to grab ahold of. Polypropylene is used as it floats in salt water. Also on the outside of the raft, on the bottom, are foot straps that you can place your feet in and grab the lifeline to turn the raft upright if it is inverted. At the entrance to the raft is a nylon webbed boarding ladder that hangs down into the water so you can climb up and in the raft. You would not be able to do so without it.
What may be preloaded into the raft will vary with the vessel and the nature of her voyage. For an idea of what the USCG requires you can read here: Life Raft
There generally is a water-making kit as well as signalling gear. Offshore rafts would likely have provisions consisting of mylar bagged water, condensed milk, and hard tack biscuits. There will be a hand operated pump very similar to the portable hand bilge pumps you'll see in the sailnet store. There will be a knife on a lanyard secured near the entrance to the raft and it will be a safety knife in that it is really a sharpened closed hook for cutting line, not at all like a conventional knife so that no damage can happen to the raft inadvertently.
The raft will be international orange with reflective patches sewn on it top and bottom. Some rafts come equipped with a strobe light atop.
The canopy and the raft itself are kept inflated by buoyancy tubes around the sides and running up the canopy. You can jump onto the canopy of the raft and do it no harm although you may have to enter the water to then enter the door of the raft.
The most common mistake in liferaft deployment, resulting in disaster, is to not secure the lanyard when deploying the raft. On a boat that is sinking, with a valise type raft, you would secure the lanyard, deploy the raft, and then cut the lanyard at the raft once on board. In a panic, people deploy the raft relying on holding the lanyard by hand. Once they yank on the lanyard and the raft inflates it immediately acquires quite a bit of windage and can pull the lanyard out of the person's hand. Given the amount of wind present when a boat or ship usually goes down the strain can be quite powerful. The crew is then reduced to trying to swim after the raft which is nigh on to impossible while wearing a life jacket. And the raft makes far more leeway than a swimmer does.
For me, I like the story where the lanyard is well secured to the boat and our grateful passengers are watching the last of their yacht slip beneath the waves before they realise that the sinking yacht is pulling the raft down with it! That's why the knife by the door is secured with a lanyard right by the door next to the inflation lanyard and also why the unfamiliar looking device is clearly labelled, "knife"! It's also quite impossible to get all of the water out of one of those rafts and, since there is no solid "floor" to one, it's passenger's bottoms make a low spot in the floor and remain perpetually wet. And everytime you unzip the door you get more water in, too. There are no windows in a raft so you can only see out by opening the door. Once on board, the raft is self-righting if the passengers hook their arms through the webbing that runs around the perimeter of the inside of the raft.
the only other thing I can think to add is that attempts to inflate the raft on board the deck of a boat will result in inflation and probably the propulsion overboard of the persons doing so. The inflation is quite rapid and you're not going to get out of the way in time if it's inflating right next to you.
  #13 (permalink)
Old 05-14-2008
Zanshin's Avatar
Zanshin Zanshin is offline
Zanshin is on a distinguished road
Bajagirl -the Type "A" is only illegal in the USA, the rest of the world isn't quite as draconian or advanced - they will be phased out for the most part at the end of this year.
The most common problem is that people don't register their EPIRB and there are cases where they functioned correctly and the system tried to track down the ownership but in the end nobody responded.
Zanshin - 残心
  #14 (permalink)
Old 05-14-2008
Cruisingdad's Avatar
Cruisingdad Cruisingdad is offline
Moderator
Cruisingdad has a spectacular aura aboutCruisingdad has a spectacular aura about
Originally Posted by camaraderie View Post
A four person liferaft is good for two. Space "per person" on rafts is minimal and most would find 4 person raft just about right for two.
ALL life rafts inflate automatically...they have a line that is secured to the boat and when that line is pulled by the deployment of the raft, the air cannister inflates the boat. SOME live raft cannisters deploy with a hydrostatic release...others require the raft to be thrown overboard...which requires some strength as they can be quite heavy (79-80lbs.)
I would stay on my boat until it was absolutely clear that it was going down...no point staying any longer or waiting till the last second.
Suggest you answer the question WHY they don't have an EPIRB beacon as this is pretty standard equipment for cruisers and results in a speedy rescue. Suggestions include...beacon trapped on submerged boat and not with the raft. Beacon is old and battery dies quickly as raft drifts away.
Suggest you decide what equipment will be included on the raft. All life rafts are packed with some survival and signalling stuff...check out some options here:
Plastimo USA
If you want some drama...the raft can be old an not recently inspected and have a slow leak when inflated. Included patch kit and manual hand pump can be used to keep afloat.
Hope this supplies some fodder for you...good luck!
That is pretty much right on.
- CD
Sailnet Moderator
Catalina 400 Technical Editor
  #15 (permalink)
Old 05-14-2008
bajagirl bajagirl is offline
bajagirl is on a distinguished road
Thanks again!!! So much great info. Sailaway21, that's perfect, just what I was looking for. Unfortunately, we get few sailboats here, otherwise I'd just pop down to the wharf and have a chat.
I will spend a few hours researching today.
Cheers - Kristene
  #16 (permalink)
Old 05-14-2008
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
Bajagirl-
Liferafts and their use are pretty much the same, regardless of whether it is a power boat or a monohull sailboat.
If you're new to the Sailnet Forums... please read this POST.
  #17 (permalink)
Old 05-14-2008
hellosailor's Avatar
hellosailor hellosailor is offline
hellosailor will become famous soon enough
Ugh, Alex? "throw in the water..pull cord..goes"
Once you throw away the raft there's no cord in your hands to pull on, is there? [g]
If that cord is attached to something--it pulls itself when you throw the raft. If it isn't attached, you'd better be holding it firmly, or you'll have to dive in after it.
Kristene, if you look for EQUIPPED TO SURVIVE - Outdoors Gear, Survival Equipment Review & Survival Information (as mentioned) on the web, check out other resources for life rafts and the results of life raft tests that have been done, I would think you could find videos or at least good stills online showing you the process. If there's nothing online, contact some makers and ask if they can email any actual videos to you.
Is there any repack station on your island, or nearby, that might let you come over and watch them inflate and test a raft during a repack sometime?
  #18 (permalink)
Old 05-14-2008
artbyjody's Avatar
artbyjody artbyjody is online now
One word: Jiblet
artbyjody is a jewel in the roughartbyjody is a jewel in the roughartbyjody is a jewel in the roughartbyjody is a jewel in the rough
Send a message via AIM to artbyjody Send a message via Yahoo to artbyjody
The life raft story so overplayed - why not have them have to suffer at sea in an inner tube or say they have a 50 footer that has a kiddies pool / inflatable jacuzzi strapped to the foredeck. Or they manage to strap all of their floatable cushions into a raft by cutting up the halyards and jerry rigging using the remainder of the mast that they cut off to make the raft, and manage to launch it by cutting the the last stay just as the vessel decides to make headway to davy jones locker...
life rafts....phfff
-- Jody
S/V "Hello Gorgeous" - 1983, Barberis Show 38!
Sailing is realizing you are the master of your domain, while recognizing that said domain is actually only on lease - with ever changing conditions of terms. - (me)
  #19 (permalink)
Old 05-14-2008
nolatom nolatom is offline
nolatom will become famous soon enough
KK,
most liferaft problems are at the very beginning. Typically, the small ones don't have water stability/weight pockets underneath and are prone to being blown upside down when launched in bad weather. Loss of many vital supplies could result.
The commercial liferafts on ships are required to be serviced by a factory every year. years ago, I was a Coast Guard inspector who had to sit in on this boring process, but it meant all the gear, and the boat, got looked at every year.
For the smaller yacht-type ones, they might not get much inspection at all once sold.
Don't know if this works into your plot, but good luck with the writing.
  #20 (permalink)
Old 05-14-2008
Just had a quick overview of the Equipped to Survive website - terrific, very detailed! No repack station here...heck, when we get celery at the grocery store it's a big deal. LOL. Think small. I will have a look at some of the power boats at the wharf today but most of the boats here are small fishing vessels.
I have my work cut out for me today - mil gracias! You've all given me tons to work with; I'm very grateful.
Smiles - Kristene
Display Modes
vB code is On
Life Raft Stowage: The Overlooked Necessity PracticalSailor Gear and Maintenance Articles 0 07-09-2007 02:21 PM
What's the big deal... yachtsea Cruising 60 08-21-2006 07:09 AM
Help Us Test Life Rafts DSRitter Gear & Maintenance 1 07-15-2002 06:01 PM
Liferafts SailNet Miscellaneous 0 08-27-2000 08:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
