Blogs
User Name
  #11 (permalink)
Old 05-15-2008
48Dodge 48Dodge is offline
48Dodge is on a distinguished road
Also, I SHOULD have the keel supported so that it's taking most of the weight, but I have had to do some work on the centerboard and trunk.
  #12 (permalink)
Old 05-15-2008
Sorry for all the back to back posts
I just remembered that another option is to build a gallows setup. Wouldn't take much. Just build a sawhorse like I have for the front only several feet taller than the boat and wider than the trailer. Attach slings and some way to winch the boat up. Lift the rear of the boat, support it. Lift the front of the boat, pull the trailer out, then support it.
  #13 (permalink)
Old 05-15-2008
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
One site that you guys might find rather useful is this one: THE SAGULATOR... which allows you to calculate loading and deflection using a wide variety of building materials.
—Captain Malcolm Reynolds, Serenity (slightly edited)
If you're new to the Sailnet Forums... please read this POST.
  #14 (permalink)
Old 05-15-2008
Bermuda30's Avatar
Bermuda30 Bermuda30 is offline
On Blocks
Bermuda30 is on a distinguished road
Originally Posted by TrueBlue View Post
Bermuda30's solution however, in post #4, scares the bejeezes outta me . . . check out that beam's deflection (g).
And that was a 6x6. I was out of town, and a few of us share the trailer, so that is how they did it. Trust me, if I was there, it would not have happened so. Boat weighs 5600#. Once off the trailer, it was properly blocked and set on stands. Interesting will be how we get it back on the trailer.
1971 Grampian 26
Display Modes
vB code is On
Re-naming the boat pirateofcapeann General Discussion (sailing related) 102 05-22-2008 09:48 AM
Modern Hull forms and Motion Comfort Jeff_H Sailboat Design and Construction 13 11-15-2007 10:40 PM
Name Change for Older Yacht ChiefOren Buying a Boat 12 10-08-2007 10:59 PM
Naming and Renaming Your Boat Sue & Larry Buying a Boat Articles 0 12-15-2003 07:00 PM
Performing in Light Air Brian Hancock Learning to Sail Articles 0 01-15-2003 07:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
