Jib or Main question? - Page 3 - SailNet Community
post #21 of 28 Old 05-28-2008
CBinRI's Avatar
I like a reefed main for stability and as much jib rolled out as seems appropriate, except that it you roll it in too much, you're probably better off with no jib.
CBinRI is offline
post #22 of 28 Old 05-28-2008
Originally Posted by btrayfors View Post
This statement is misleading. Most modern sloop-rigged boats will sail very well to windward with the genoa alone, including being relatively close-hauled. You don't necessarily need to have any mainsail out. Once in the BVI I sailed past a 50' ketch with a professional crew and flying all sails beating to windward, in a Pearson 10M with the genoa alone!
While you can reach OK with just the main, most boats will do better (sail faster) with just a genoa. And, as you've noted, it's much easier to roll in or out to set the area needed for the wind conditions and point of sail.
When going upwind, most boats will go very slowly under main alone. They really need a headsail in order to make the main an efficient contributor to boat speed. The difference is really dramatic. Try it yourself: set a course closehauled in a decent wind, note your boatspeed, then drop (or furl) the headsail, leaving the full main. Your boatspeed will fall off to almost nothing. By the way, this isn't a bad way to sail up to a mooring in a strong wind.
Bottom line: for your trip I'd start out with just the genoa and see how it works. If the wind falls light and you need more sail area, then put up some main. Of course, an alternate strategy would be to tuck in a reef in the main before setting out, and unroll enough genoa to get your boatspeed up.
Bill
I don't necassarily disagree, but I don't think my statement was was misleading. You can't hold close-hauled in really heavy air (though you might be able to close-reach), without some sail area aft (meaning a reefed main, or a storm trysail) and a foresail too. You just won't make it around unless you have both a mainsail and storm jib, no matter how small. With no jib, the C/E is just too far forward without any headsail, and the CLR just too far aft, to bring her about without some headsail. If you don't have to tack, fine. But if you do, in order to stay off a lee shore, then you have to have some sail in the aft half of the boat in order to head up, and you have to have some headsail to get you through a tack.
nolatom is offline
post #23 of 28 Old 05-28-2008
Thanks Courtney.
nor can you tack, without some sail area aft (meaning a reefed main, or a storm trysail). You just won't make it around with just a foresail.
I have to disagree on that one. I've done it many times without a problem. However, as has been said, all boats behave a little differently and this may be an issue with yours. It isn't true as a general rule.
My sail choice when the wind kicks up is full 145% genny and mizzen. Works well 'til around 27-28 kts. wind, then roll in a bit of the genny. Obviously this won't work on most boats.
hunter Legend 37 Semper Paratus
Formerly - Tartan 34C Yawl
T34C is offline
post #24 of 28 Old 05-28-2008
RickQuann's Avatar
If it's blowing hard, I usually reef the main in advance, before getting underway. As a preference, I'll sail under main alone verus jib alone, but a little headsail with a reefed main tends to balance my rig the best, especially upwind.
RickQuann is offline
post #25 of 28 Old 05-28-2008
Send a message via Yahoo to baileywick
I have a Niagara 35, large fore triangle. In > 15 knots, start of white caps on Chesapeake Bay, I routinely sail with just the roller furling 135 % genoa. As I have gotten more a senior citizen, I find removing the sail cover, hauling the main up, and replacing the sail cover not to be as much fun as just unfurling the genoa. I have no problems with unbalanced helm, etc. She sails at hull speed on just the genoa with 20 knots wind!
Baileywick, 1979 Niagara 35 Classic, Chesapeake Bay,
baileywick is offline
post #26 of 28 Old 05-28-2008
philsboat's Avatar
When sailing shorthanded in high winds I like to use the main only with lots of shape well forward .This works on all points of sail even going to windward if you don't sheet the main past the lifelines.No winches to crank just sit back and steer.
Mirage 25 masthead
philsboat is offline
post #27 of 28 Old 05-28-2008 Thread Starter
nk235's Avatar
Since I first started this thread I have done a lot of experimenting in different wind conditions with different sails. One day it was blowing 15-25mph and I had a reef in the main and the geneo 3/4 unfurled. I was doing between 5.5-6.5 knts and the helm was balanced so nicely that I could have steered with my pinky. The boat actually does sail very nicely with just the genny but there is a far amount of weather helm. It does not particularly sail well with just the main. I'v also learned it is different with every single boat. My last boat was a 25' with a very tall main stepped further toward the bow than most boats and also with a very small fractional jib. That boat sailed excellent with just the main and very poor with just the jib. The Morgan 323 I have now is my first mast head sloop with roller furling and I just bought it this season so I didn't know what most others did in different conditions. Now that I have been out on it a lot more I am starting to get a feel for how this particular boat responds in different winds with different sail combos out there. I can tell you though it is real satisfying to have the boat cranking along over hull speed and also having the helm be perfectly balanced so you know you are sailing the boat correctly.
nk235 is offline
post #28 of 28 Old 05-29-2008
Sailing with only a jib
I have an Ericson 29 which I have sailed many times with only a jib in 20 knots plus. Usually I use a beat up old 100%, hanked on jib and the boat sails well both to windward and reaching. Admittedly it does not point as high with just the jib as with both jib and main. I also don't crank it all the way flat. I can get 5 to 6 knots in a 25 knot wind beating to windward at about 55 degrees off the wind. Advantages of using just the jib are the boat does not heel as much, no rounding up during gusts, less fighting the wheel, only one sail to take down, etc. Some people have told me that using only the jib stresses the rig. As an engineer I can not see how having less sail up causes more stress, but then I have not done a finite element analysis of both cases.
Try it on your boat.
kenjnott is offline
Convert jib from hanks to furling? Quickstep192 Gear & Maintenance 10 09-27-2007 11:13 AM
slugs catching upon raising main remazerov Seamanship & Navigation 24 09-04-2006 08:03 PM
The Lessons of Fear Kristin Sandvik Her Sailnet Articles 0 08-28-2003 09:00 PM
Sailing Basics Steve Colgate Her Sailnet Articles 0 03-09-2003 08:00 PM
Spinnaker Takedown Basics Dean Brenner Racing Articles 0 04-28-2002 09:00 PM
