Server is SLOW!!! - Page 2 - SailNet Community
post #11 of 18 Old 05-23-2008
Larus Marinus
Idiens's Avatar
Do you have a dummies guide to doing that on XP?
Jonathan-Livingston
Idiens is offline
post #12 of 18 Old 05-23-2008
Idiens-
Go to the start menu and click on "RUN"
Type "CMD" in the dialog box and hit "RETURN"
TYPE "cd C:\windows\system32\drivers\etc\" and hit "RETURN"
Type "attrib -r -s hosts" and hit "RETURN" — This is to remove the read-only and system attribute properties from the file, since you need to edit it.
Type "notepad hosts" and hit "RETURN"
In the Notepad window that then opens, go to the bottom of the file and type "127.0.0.1 youchoose.net"
Save the file and quit Notepad. In the CMD window, type "EXIT" and hit "RETURN"
You will probably have to reboot for the modified hosts file to take effect.
If you type the quotation marks and run into a problem because of it, I will fly out and beat you about the head and shoulders... TYPE ONLY WHAT IS IN THE QUOTES. BTW, you did say dummie's guide to doing this.
sailingdog is offline
post #13 of 18 Old 05-23-2008
Idiens-
I prefer to say " A Knotheads Guide" Thanks SD
knothead is offline
post #14 of 18 Old 05-23-2008
PO-TAY-TO, PO-TAH-TOH... Same thing....just different pronounciation... dummy, knothead... whatever.
You've got to remember that the guide was written by a dog for a seagull... so how high-level can it be.
post #15 of 18 Old 05-23-2008
Ouch Again!!
knothead is offline
post #16 of 18 Old 05-23-2008
Larus Marinus
Idiens's Avatar
Excellent SD. That was just about my level.
So having followed the instructions faithfully, should I notice a difference and is there a down side?
Thank you
P.S. I tried to give you another rep+ point but I am not allowed.
Jonathan-Livingston
Idiens is offline
post #17 of 18 Old 05-23-2008
Idiens-
If you try going to Youchoose.net or seeing content from there it will fail. That's the only downside...
post #18 of 18 Old 05-23-2008
Larus Marinus
Idiens's Avatar
Thanks - it sounds like an upside....
Jonathan-Livingston
Idiens is offline
nor 'Sea 27... are they as slow as they look? starboardyacht Boat Review and Purchase Forum 10 02-10-2008 02:05 PM
Slow SailNet server? TrueBlue Announcements and Suggestions Box 3 05-16-2006 06:25 PM
Slow boat to China @ Scott's Blog NewsReader News Feeds 0 04-10-2006 04:17 AM
How to Slow Down and Stop John Rousmaniere Learning to Sail Articles 0 08-03-2003 08:00 PM
How to Slow Down and Stop John Rousmaniere Seamanship Articles 0 08-03-2003 08:00 PM
