Fishing net tangled in prop - Page 2 - SailNet Community
post #11 of 13 Old 05-26-2008
Freesail99's Avatar
If you're diving to cut the rope... DON'T wear the PFD... Swimming down with a PFD on is tough
So is drowning .......
S/V Scheherazade
Freesail99 is offline
post #12 of 13 Old 05-26-2008
What my friends have done in that situation, they tie a FOAM PFD to a line, and then when they get tired, they get into the PFD...
sailingdog is offline
post #13 of 13 Old 05-26-2008 Thread Starter
Originally Posted by Fstbttms View Post
Not worth the effort, IMHO.
1.- It would only provide limited protection. Anything floating above the guard could slide down the hull as the boat moved past and become entangled.
2.- The guard will be a wonderful place for fouling organisims to set up shop. Long, leafy vegetables and big communities of shelled animals do not enhance performance, whether under power or sail.
3.- The guard itself could break and become an entanglement.
If you are really so concerned about fouling a prop, maybe you should consider a shaft-mounted line cutter.
Good points to consider. How effective are the shaft cutters? I realize they would work well on lines, but what about nets? Has anyone heard of the prop getting tangled even with the cutters?
I'm not looking for mass approval. Is everybody ok with that?
dwightgry is offline
Net Gain - Elevating the Stowage Capacity of Your Boat Don Casey Gear and Maintenance Articles 0 12-02-2004 08:00 PM
Atlantic SSB weather channels ughmo2000 Cruising & Liveaboard Forum 6 11-27-2004 07:57 AM
Choosing the Right Propeller Sue & Larry Gear and Maintenance Articles 0 02-04-2003 08:00 PM
Fishing Under Sail Don Casey Her Sailnet Articles 0 04-18-2002 09:00 PM
Fishing for Sailors SailNet Cruising Articles 0 09-15-2001 09:00 PM
