- Quick Menu
05-26-2008
Mildew
I know this topic has come up before and I have done some searches on it here but didn't really get a clear answer from it, so I am starting a new mildew thread.
I went to see my boat yesterday, the first time in a long time because of business commitments, it was a great day! The boat is older and lets a little water in over time, so the bilge had maybe 2 inches of water and needed to be pumped out, not bad for as long as it has been sitting alone. The trouble is, adequate ventilation is not going to cure this problem, and it isn't enough bilge water to effectively use a pump to periodically get rid of it (as far as I know). So unless I want to rebuild the boat to stop it, I am pretty much stuck with a small amount of bilge water - even when I do pump it out I am not able to get all of it, just most of it.
So the question is, what do I do about the mildew that grows in the boat when I really can't do much about the water ? Do I have to live with it ?
What are you pretending not to know ?
05-26-2008
How about hooking up a de-humidifier?
Ron Paul 2012
"wikijar"
05-26-2008
Larus Marinus
Do you have shore power?
Jonathan-Livingston
05-26-2008
I do have shore power, a de-humidifier is an option. Will that do the trick ? The boat is sealed, essentially, so if the de-humidifier needs some kind of an outlet to the outside world I will have to create one. Same for any kind of ventilation, if there has to be outside air involved I'll have to create some way to get to it.
05-26-2008
Adding more ventilation has to help stop the mildew. Have you thought about adding a couple of solar vents ?
S/V Scheherazade
I had a dream, I was sailing, I was happy, I was even smiling. Then I looked down and saw that I was on a multi-hull and woke up suddenly in a cold sweat. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
05-26-2008
Freesail 99, No I haven't checked, but I can check.
I thought ventilation wouldn't do anything if the boat has standing water in it, because it would always be moist ? Are you all saying that even with standing water the ventilation is going to stop the mildew, or better control it ?
05-26-2008
Maybe you could set it up to drain into the galley sink.
Ron Paul 2012
"wikijar"
05-26-2008
I had this problem in my boat. I couldn't stand the smell of it because of the mildew. I poured bleach into the bilge and let it sit for like a week then I pumped out the water. it smells like bleach for a little while but the mildew is gone. When I went down to help out in mississippi after hurricane Katrina we would do this to the houses. Gut it and then spray all framing down. Thats where I learned that from.
05-26-2008
What I am saying is with two solar vents one on in take and the other on out take you will keep the air moving, which should slow or stop mildew from forming.
I use it on my boat and it has cut that smell you get when you first open up the boat to just about nothing.
S/V Scheherazade
05-26-2008
Pouring chlorine bleach into your bilge for a week is a really bad idea if you have any metal in the bilge. Chlorine bleach will aggressively attach aluminum and stainless steel. It can also attack a lot of the plastics and rubber used in a boat..
| Thread Tools |
Search this Thread |
