05-27-2008
Most of the trailerable multihulls will fold down to 8'6" or so. However, if you're looking at a trailerable multihull... and need to keep it in a single width slip, then you probably should look at the Telstar 28 rather than the Corsair 28/31/36. The Corsairs can't be stored with the amas folded, since the folding system leaves the ama hull-deck join in the water.
