Old 05-29-2008
groundhog is on a distinguished road
Sail folding..
Is there an easy way for one person to fold a jib/genoa?
thanks,
gh
Old 05-29-2008
DO you have a forward hatch??
If you do I teach you a trick..
Old 05-29-2008
If you don't have a forward hatch, then normally the boat is small and just take the sail to a surface, and fold it there...or on the cockpit...
Old 05-29-2008
Idiens's Avatar
Larus Marinus
Idiens is on a distinguished road
Yes. Please!
Jonathan-Livingston
Old 05-29-2008
But..if you have one..
just throw the sail inside thru the hatch but leave the tack end outside.
You then hold the tack and make a cylinder, while you stand outside with one leg on each side of the hatch, and as you make the cylinder along the sail's luff (the part that slides up the mast) pulling more as you go...
Once you have made a nice cylinder with it..pull it outside, carefully as to not unrap it and fold the cylinder.
If the sail is small enough, do this while just standing up.
That's how we folded on the 470's at sea or when alone, because we launched from beaches and didn't want the sand in the sails.
If this was not clear I will make a drawing.
Old 05-29-2008
Idiens's Avatar
Larus Marinus
I think I get the idea, I will try it soon. Thanks Alex.
Jonathan-Livingston
Old 05-29-2008
Here are some drawings..
Step one
send the sail down the hatch, if it's a large sail, or simply keep it at your feet if its a small sail...
Pick up the tack end and with both hands start rolling the sail along the luff.
Remeber that as you roll the sail, one hand keeps holding the roll at the tack portion as you rotate the roll (the roll rotates). Not pull the sail around..rotate the roll.
Keep rotataing the roll slowly holding each turn, so the whole luff is in one of your hands..
keep doing till you have the head of the sail in your hand
Once you d, pull the roll out, and lay it on the floor deck or whatever you are..you can also do this inside if its wet outside.
You're done...
the beauty is it will never fold in the same spot, which is good for the sails.
I do this with my main sail, and that is one big sucker..
Old 05-29-2008
Stryker72's Avatar
Stryker72 is on a distinguished road
If there isn't a forward hatch do you still roll it before folding?
Old 05-29-2008
NOLAsailing's Avatar
NOLAsailing is on a distinguished road
I roll my main, because of the battens, but I flake the headsails. I fold the headsails just like you would with two people, just walk back and forth and carefully smooth out the folds. It's not too bad and it's much easier off the boat.
-Jason
Old 05-29-2008
nolatom will become famous soon enough
To answer your question, as succinctly as possible:
No.
Heavy weather sailing sailorfrank Learning to Sail 18 08-24-2009 01:24 PM
Sloop, Cutter or Ketch jsgsail Boat Review and Purchase Forum 17 12-26-2008 02:47 PM
Traveler usage? Humpwalker Seamanship 22 02-17-2007 10:54 AM
Considering a New Mainsail Brian Hancock Cruising Articles 0 04-29-2004 08:00 PM
Sail Trim Steve Colgate Learning to Sail Articles 0 05-10-2000 08:00 PM
