Old 06-01-2008
BlowinSouth's Avatar
"On a Tartan 30"
BlowinSouth is on a distinguished road
Send a message via Yahoo to BlowinSouth
Gasoline in the water tank...HELP!
It's obvious that some previous owner/gas dock person put gas in the water tank by mistake. The water has a very distinct gasoline taste and is undrinkable.
The tank is 40 gallons and I've cycled two full tanks through it with no affect on the taste. Any ideas on how to clean it with out removing/replacing it? Additives? Detergents? Etc...?
Old 06-01-2008
Boasun's Avatar
Boasun will become famous soon enough Boasun will become famous soon enough
Try steam cleaning...
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
Old 06-01-2008
T37Chef's Avatar
Senior Culinary Member
T37Chef will become famous soon enough
Baking Soda
Shawn
S/V Windgeist
Tartan 37C #358
Photo by Joe McCary
THE Yacht Builders List:
Useful Food Purchasing Links:
Old 06-01-2008
Great Lakes Sailor
padean is on a distinguished road
Baking soda for gasoline taste
Is baking soda in the water tanks just good for gasoline, or for other odors/tastes as well. How much would you use?
PDean
CS 34
Saginaw Bay, Michigan
"The pessimist complains about the wind; the optimist expects it to change; the realist adjusts the sails." - William Arthur Ward
Old 06-01-2008
uspirate's Avatar
Trim for Sail
uspirate has a spectacular aura about uspirate has a spectacular aura about uspirate has a spectacular aura about
try Chlorine!
signature
BJ & Nimfa
S/V Flocerfida
Old 06-01-2008
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
There also maybe fuel residue in the distribution lines as well, giving up just enough to taint the water
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
Old 06-01-2008
camaraderie's Avatar
moderate?
If the baking soda doesn't work...a bleach shock treatment may help. Here's a repeat post on how to do it:
Shock Treatment Should be Tried before replacing tanks. Here's how:
With thanks to Peggie Hall of Raritan...
Fill the water tank with a solution of 1 cup (8 oz) of household bleach per 10 gallon tank capacity. Turn on every faucet on the boat (including a deck wash if you have one), and allow the water to run until what's coming out smells strongly of bleach. Turn off the faucets, but leave the system pressurized so the solution remains in the lines.
Let stand overnight-- at least 8 hours--but NO LONGER THAN 24 hours. Drain through every faucet on the boat (and if you haven't done this in a while, it's a good idea to remove any diffusion screens from the faucets, 'cuz what's likely to come out will clog them). Fill the tank again with fresh water only, drain again through every faucet on the boat, repeating till the water runs clean and smells and tastes clean.
Cleaning out the tank addresses only the least of the problem...most of the problem occurs in the lines, so it's very important to leave the system pressurized while the bleach solution is in the tank to keep the solution in the lines too.
People have expressed concern about using this method to recommission aluminum tanks. While bleach (chlorine) IS corrosive, the effect of an annual or semi-annual "shock treatment" is negligible compared to the cumulative effect of holding chlorinated
city water in the tank for years. Nevertheless, it's a good idea to mix the total amount of bleach in a few gallons of water before putting it into either a stainless or aluminum tank.
To keep the water system cleaner longer, use your fresh water...keep water flowing through system. The molds, fungi, and bacteria only start to grow in hoses that aren't being used. Before filling the tank each time, always let the dock water run for at least 15 minutes first...the same critters that like the lines on your boat LOVE the dock supply line and your hose that sit in the warm sun, and you don't want to transfer water that's been sitting in the dock supply line to your boat's system. So let the water run long enough to flush out all the water that's been standing in them so that what goes into your boat is coming straight from the water main.
Finally, while the molds, fungi and bacteria in onboard water systems here in the US may not be pleasant, we're dealing only with aesthetics...water purity isn't an issue here--or in most developed nations...the water supply has already been purified (unless you're using well-water). However, when cruising out of the country, it's a good idea to
know what you're putting in your tanks...and if you're in any doubt, boil all water that's to be drunk or used to wash dishes, and/or treat each tankful to purify. It's even more important in these areas to let the water run before putting it in the tank--wash the boat, whatever it takes...'cuz any harmful bacteria will REALLY proliferate in water hoses left sitting on the dock.
Old 06-01-2008
fullkeel7 is on a distinguished road
BS,
Cam beat me to it. We used to (and still do) treat comm. aircraft potable water systems the same way, although the soak time was 4 - 6 hours. Well, we never had your kind of contamination to deal with either. All supply lines were made of aluminum, so I can verify that corrosion is not a significant factor. With your boat in the water, you might want to ask how the marina feels about emptying the solution into your sinks and therefore into the water. If it's taboo, I would suggest only filling your tank to 1/4 to 1/2 capacity and following the suggested procedure. Then 'bleed' the system into buckets and dispose of to the marina's specs. That might save on the bucket brigade.
I'm not sure whether chlorine will 'cut' the petrolium base gas but the treatment is sure worth a try. Otherwise, you just may have to pull the tank. Good luck with it.
Bob
Old 06-02-2008
timebandit's Avatar
timebandit is on a distinguished road
I know the answer to this one!!!
It seems to happen on motor homes more than you might think.
The fix---
Flush tanks with water
Empty
Fill with one half capaticy of red wine
Add water to top off
Run mix through plumming a little
Top off with water and let set for 24 hours
Flush with fresh water
Rick
Old 06-02-2008
TrueBlue's Avatar
Señor Member
TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough
Never heard of this remedy before. But with the need for 20 gallons of red wine, even using the cheap jug wine will be a pricey fix.
True Blue . . .
sold the Nauticat
water tank buildup smaconf@msn.com Hunter 2 11-30-2007 08:51 AM
Repairing an integral fiberglass water tank welshwind Gear & Maintenance 12 07-11-2007 12:46 PM
Water, Water Everywhere Tania Aebi Cruising Articles 0 06-14-2004 08:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
Safety Check Mark Matthews Learning to Sail Articles 0 01-25-2000 07:00 PM
