06-10-2008
go with stainless steel, go to your local metal supply store and check there drops area, you can and will find plenty of pieces that will be big enough to make your tank. to bring the cost down do all the cutting yourself and find someone to weld it for you. Stainless is a better option than aluminum and even plastic tanks, there is a reason most all the hardware on your boat is stainless, except for your mast which is aluminum for weight and flex.
Scott
