Old 06-12-2008
nestorph is on a distinguished road
Equipping a boat for a dog
I've decided to start bringing my one-year old Lab aboard for the day sailing I do in my area. I've install a net from the bow (just short of the pulpit) back to the section with the removable lifeline (for boarding) and now am wrestling with that section as I have to figure out how allow for entrance of my jibsheet which comes through there when I'm using genoa. That's question 1.
The second question is what techniques have folks used to "boatbreak" a housebroken dog? I read somewhere else that pet owners provide a litter box in the cabin, but since my dog has never had to use one, how to I teach her to use it?
Thanks for any ideas.
Old 06-12-2008
Boasun's Avatar
Boasun will become famous soon enough Boasun will become famous soon enough
Ensure that the dog stays away from the mast. For they will think it is a tree or a fire hydrant and piddle all over it.
Put a square of astro-turf where you won't step on it and train your dog to use it. Then to clean it, just drag it behind your boat for a mile or so.
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
Old 06-12-2008
Freesail99's Avatar
Freesail99 will become famous soon enough
There are so many threads on sailing with dogs, please do a search on here.
S/V Scheherazade
Old 06-12-2008
Hydrant substitute...
All the dogs I've had were/is female and I notice that they don't aim for trees or hydrants but tend to squat. I'll keep a heads up on the mast anyway. As for the astroturf, how do you keep it fixed to the surface while underway?
Old 06-12-2008
Boasun's Avatar
Put grommets in the corners of the square and lash it in place.
Maritime Instructor
S/V Rapture
Old 06-12-2008
fullkeel7 is on a distinguished road
Wouldn't that technic work on the lower portion of a porta potty?
Old 06-12-2008
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
Go to the pet store and buy training pads, they're about 2' square, very absorbent and have a leak proof backing, put it in a place she will see a the time.
If you have a male dog wrap the compression post or mast and table legs, they will use them.
also make it a routine to take dog poop every morning and every evening, they will learn that that's the time
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
Old 06-12-2008
I reread your post, I don't think you'll have a problem underway, it will be at port and while in the cabin you'll have to worry about.
Get a vest for her, if you haven't already
1978 Tayana 37
Old 06-12-2008
S/V Lilo, Islander 32
IslanderGuy is on a distinguished road
As for the Sheets question, I have kids and installed netting from the pulpit all the way to the push-pit, with a cut for the lifeline gate so I can still open it. (For now I just tied a bunch of rope up and down the netting, then run a bungee through it to close the gap, and tie the top and bottom. Soon I will come up with a better solution, but works for now.)
I simply run the sheet through the netting at about the right place, just eyeballing it. the netting has some give so it will pull one way or the other. This seems to work out fine. I had this on my last boat too and used it for a couple of years without to much ware, however I am seeing some unraveling of the netting from the sheets, but the netting still does its job. Netting should be replaced every couple of years I think due to UV breakdown anyway, so I do not see this as a huge issue, and worth the added security. I also have better quality netting this time so it might hold up better. I just installed it a few weeks ago on the new boat, so only time will tell.
S/V Lilo
1964 Islander 32
Saint Helens, OR
Old 06-12-2008
Jonesee is on a distinguished road
I have a different take. I've had Labs for 20 years. Until they are 2 years old, they are chewing up everything in sight and mine are very well behaved. At 1 year has she quit chewing??
If not, I wouldn't want to foot the bill for what a bored Lab can destroy on a boat!!! Hmmm a bored Lab in the cabin alone for 2 hours...that will put a dent in your wallet.
I love them to death, if they ever perfect cloning there isn't much I wouldn't pay to have one of mine back, but damn do they chew up a lot of stuff.
What's your biggest bonehead move sailing? CharlieCobra Seamanship 421 09-26-2011 10:05 AM
Making Passage w/o a Rudder wind_magic Seamanship 60 07-16-2010 01:23 PM
Naming and Renaming Your Boat Sue & Larry Cruising Articles 0 12-15-2003 07:00 PM
Fine-Tuning the Autopilot, Part Two Dan Neri Gear and Maintenance Articles 0 10-13-2003 08:00 PM
Performing in Light Air Brian Hancock Learning to Sail Articles 0 01-15-2003 07:00 PM
