06-20-2008
A swing keel is just a heavily weighted centerboard generally. A lifting keel is a totally different beast. Swing keels and centerboards serve much the same purpose, in the same way, with the swing keel having a bit more to do with righting moment than an unweighted centerboard would.
This photo is of the lifting keel used in a Tide 28 sailboat.
My boat has a centerboard, which is made of wood. It is buoyant and must be held in the down position.
A Southerly 46RS has a swing keel, which is weighted and in the case of the Southerly RS weighs about 4800 lbs. Functionally, it combines the righting moment features of a lifting keel, with the center of lateral resistance features of a centerboard.
