Old 06-23-2008
Serve's Avatar
Serve is on a distinguished road
Catboat Toping Lift Problem
On my maiden sail with my 15 foot Sandpiper, the toping lift line got caught up in the sail. Any suggestions as to what I did wrong?
EG
Old 06-23-2008
JohnRPollard's Avatar
Moderator
EG,
With topping lifts, it's usually a question of easing them sufficiently. Because you are sailing a gaff-rigged boat, the topping lift will need to be eased much more so than on a typical marconi rig. It should be completely slack, flopping around quite a bit, in order to allow the sail to take its full shape. Of course, you would ease it only after hoisting and belaying both the throat and peak halyards.
Here is a good photo showing how much slack ought to be in your topping lift:
Marshall Sandpiper under sail
Old 06-23-2008
Serve's Avatar
Wink Thanks
I knew the solution would be quite simple. I have quickly learned how helpful the sailing community is.
Thanks.
EG,
LBI, NJ
Yanmar Starter dave6330 Gear & Maintenance 17 08-22-2010 10:03 PM
3GM: Engaging the starter idiosycrasies welshwind Gear & Maintenance 15 09-04-2008 06:08 PM
Yanmar 2GMF starter solenoid mdemuth Gear & Maintenance 13 04-09-2008 12:12 PM
philosopher's club HoffaLives Off Topic 106 12-15-2007 11:48 AM
Keel Lift NJW3 Seamanship 6 09-22-2003 06:59 PM
