Old 06-24-2008
BlowinSouth's Avatar
"On a Tartan 30"
BlowinSouth is on a distinguished road
Send a message via Yahoo to BlowinSouth
How to waterproof Sunbrella??
Is there anyway to waterproof sunbrella? The rain pools right in the center of my dodger and it drips right down the companionway. I have to put in the boards and close the hatch.
I have used Scotch Guard before on other things and it works well for a very short time. Is there something else that might work? Paint it with varnish? Inflatable dinghy paint? or ??? etc... Not that I want to 'paint' it, I want something that will waterproof it and still be invisible.
Thanks,
Steve
Old 06-24-2008
You should probably use 303 Fabric Guard. It will help, but you really need to modify the dodger so it doesn't have a low spot there.
Old 06-24-2008
erps's Avatar
the pointy end is the bow
This information sheet specificially states to avoid silicone based products on sunbrella. It looks like the product that sailingdog recommended does not have silicone in it. Our local canvas maker sells a product in a quart bottle that you brush on that restores the "water beading" quality to sunbrella. I've had good luck in the past with a boatlife product as well.
Waterproofing Canvas by Don Casey
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
Old 06-24-2008
Erps-
303 High Tech Fabric Guard is what Sunbrella's makers recommend for use on Sunbrella.
Old 06-24-2008
erps's Avatar
I can believe that. I didn't say otherwise.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
Old 06-24-2008
teshannon's Avatar
teshannon has a spectacular aura about teshannon has a spectacular aura about teshannon has a spectacular aura about
Does the water seep through the fabric or is it simply that the dodger has a low spot that drains off the edge? If the later then try tightening the dodger as SD suggested. If it's coming through the material then waterproofing sprays will help but will be a short term fix only. Before I replaced my bimini I had that problem and tried a few sprays but none lasted longer than about a month.
Old 06-24-2008
I was just clarifying why I was recommending it.
Old 06-24-2008
tommyt is on a distinguished road
BlowinSouth,
If you find the 303 for a reasonable price, post it here please. That stuff is expensive....and it does work!
It needs to be reapplied during the season, and your pooling problem needs to be fixed or you will be throwing away money.
Old 06-24-2008
JohnRPollard's Avatar
Moderator
I've had good luck with this product: PTEF
Not sure how the price compares.
Old 06-24-2008
"On a Tartan 30"
Yes, the water seeps through the fabric. The problem is that the dodger is old and as I tightenen it up to eliminate the low spot (pooling) it starts popping seams elsewhere.
I need a new dodger obviously but would like to get another season out of this one if possible. The 303 stuff sounds like a good start.
Poll which sewing machine do you use for sunbrella and sail work saurav16 Gear & Maintenance 9 04-26-2008 02:04 PM
Dyeing Sunbrella Edo Kazumichi Gear & Maintenance 3 04-19-2008 07:48 AM
Sunbrella Source Quickstep192 Gear & Maintenance 18 12-29-2007 03:57 AM
Ok, they're clean now so what do I waterproof them with? CharlieCobra Gear & Maintenance 13 11-22-2007 12:58 PM
Experience Using Gortex Thread & Sunbrella? geoffschultz Gear & Maintenance 3 02-06-2007 07:02 PM
