Old 06-26-2008
canvasmaker is on a distinguished road
Question Can I track an EPIRB signal from my nav station?
We're getting ready to buy EPIRBS -- the 406 MHz variety -- and have heard a rumor that the signal can be tracked on the boat's chart plotter. But I haven't found solid information to back this up. In case of MOB, we want to be able to home in on the EPIRB's signal and get to the person lickety-split.
Anything to this? Or is it just a dream?
Thanks
Old 06-26-2008
gtod25 is on a distinguished road
While I hate to say an absolute "No" in connection with electronics...
I think the rumor is wrong. You can track the VHF 121.5 MHZ element of an EPIRB transmission but not on a chart plotter. You need something like an Vecta2 Directon Finder (ARC Electronics.). I'm not sure that I would spend the money.
Raymarine has the LifeTag Wireless MOB System, but that only connects with a Seatalk Plotter. There may be a workaround to connect to other Plotters. Its not an EPIRB type transmitter.
But I might be wrong, and would be curious to hear of such a system.
Old 06-26-2008
JiffyLube's Avatar
Grasshopper
JiffyLube is on a distinguished road
Thanks
I don't think you can track an EPIRPS signal on a plotter, but you can track VHF-DSC with the right plotter setup.
Old 06-26-2008
IIRC, the 406 MHz signal is trackable if you have a link into the COSPAS/SARSAT computer system... AFAIK, it is not trackable by consumer grade gear.
Old 06-26-2008
Most (all?) modern EPIRB's transmit on both....
406 MHz (COSPAS-SARSAT) with your registered, digitally-coded distress signal, and 121.5 MHz (SAR homing frequency).
ACR sell a direction finder that can give the direction of a 121.5 MHz signal;
See my previous comment.
Old 06-26-2008
BTW, if you've got a MOB, chances are pretty unlikely they'd have an EPIRB with them, unless you threw it overboard when they went over the side. EPIRBs are registered to a specific vessel and are fairly bulky—a bit bigger than a coffee thermos...
What you're probably thinking of is a PLB, which is much more compact, but serves much the same function, but is registered to a specific individual.
The 121.5 MHz SART signal from both either a PLB or an EPIRB can be tracked using a directional antenna, similar to what GTOD25 has posted... but it won't generally show up on a chartplotter, nor does it have enough information to plot it on a screen of any sort, since the antennas that you can generally buy will give direction but not range AFAIK.
Old 06-26-2008
Hartley18's Avatar
Termite Fodder
Hartley18 will become famous soon enough Hartley18 will become famous soon enough
Note that it will show up on a modern (GMDSS-equipped) radar display though..
Crew member on the Womboat for:
2011 Heaven Can Wait 24Hr - Race against Cancer.
Old 06-27-2008
jerryrlitton's Avatar
Oathkeepers member
jerryrlitton will become famous soon enough
Send a message via ICQ to jerryrlitton Send a message via MSN to jerryrlitton Send a message via Yahoo to jerryrlitton Send a message via Skype™ to jerryrlitton
I believe the 121.5's are going away next year....anyone hear of this?
Jerry
"People that values its privileges above its principles will soon lose both."
Benjamin Franklin
"Those who hammer their guns into plows will plow for those who do not."
Thomas Jefferson
"First they ignore you, then they ridicule you, then they fight you, then they agree with you."
Ghandi
Old 06-27-2008
Emergency Position Indicating Radiobeacon (EPIRB)
This explains all;
Emergency Position Indicating Radiobeacon (EPIRB) - USCG Navigation Center
Old 06-27-2008
121.5 MHz EPIRBs are going bye-bye...not SAR Transponders.
Jerry
Nav Station Design Mithril Gear & Maintenance 21 07-03-2007 06:30 PM
Setting Up Your Nav Station Sue & Larry Gear and Maintenance Articles 0 07-26-2002 08:00 PM
Betting it All on EPIRBs SailNet Seamanship Articles 0 06-04-2001 08:00 PM
