Old 06-30-2008
Joel73's Avatar
1987 Pearson 27
Joel73 has a spectacular aura about Joel73 has a spectacular aura about Joel73 has a spectacular aura about
Knockdown & Sinking In Oriental
These guys keep their boat at our neighbors pier... looks like they had a bid of bad luck this past Sat. You can tell by the first photo how much it was blowin out there. Glad everyone is ok and hopefully the boat will make a full recovery.
Sailboat Sinks Off Oriental | TownDock.net | Oriental NC News
"Unthinking respect for authority is the greatest enemy of truth." - Albert Einstein
Old 06-30-2008
Sea nettles suck..and so do knockdowns. Glad to hear everyone's okay and the boat looks like it wasn't damaged too badly. Positive floatation is a good thing.
Old 06-30-2008
heinzir's Avatar
Junior Senior
heinzir is on a distinguished road
That's pretty much what happened to me several years ago, except my boat sank in 38' of water:
http://www.sailnet.com/forums/seaman...tml#post202044
It appears that the "positive flotation" didn't really keep this boat afloat either. She went down in less than 5' of water and thus was readily accessible. Needless to say, I've added LOTS more flotation to my boat.
Henry
Chiquita - 1974 Macgregor Venture of Newport 23
Old 06-30-2008
RickQuann's Avatar
RickQuann is on a distinguished road
Good thing they were in shallow water and everyone is safe.
Old 06-30-2008
arbarnhart's Avatar
arbarnhart is on a distinguished road
Nice friendly sailing grounds where I am bringing the kids this weekend?
I know, it can happen anywhere. I supposedly have positive flotation and while I don't want to absolutely rely on this, I have been unable to find an N17 knockdown story. I found a story where a guy tried and failed, testing it in high winds on purpose. Sobering story.
-Andy
Newport 17 - "Kohanna"
At sea Darwin's hypotheses is the final arbiter of right of way.
Old 06-30-2008
Junior Birdman
Iflyka200s is on a distinguished road
Catalina 22...
You can't keep a good boat down! (A jammed main sheet?) Hummmm
Tim
1980 S/K Catalina 22 # 9648
Windage
Ft. Lauderdale, FL
1988 Seaward Fox
no name yet (it's in pieces!)
Coconut Grove, Florida
Old 06-30-2008
djodenda's Avatar
djodenda will become famous soon enough djodenda will become famous soon enough
I'd guess that they didn't have the centerboard clamp engaged. Once the boat passed 90 degrees, the keel rotated back and helped capsize the boat.
The mast would have dug into the ground, and the boat flooded through the open companionway.
Boat winds up resting on the bottom.
Catalina 22s are great boats that can handle adverse conditions, but sailing in heavy weather with the keel clamp disengaged, and the companionway boards out is asking for trouble.
Don't know if that's the case here, but I'll step on the semi-informed speculation bus!
David
David
1987 CS 36 Merlin "Kyrie"
Old 06-30-2008
Joel73's Avatar
1987 Pearson 27
Hahaha! Well, i've been sailing out there as a kid several times and i will tell you that it CAN get rough. A lot of the time it's nice but occasionally there is a summer squal that blows through. If you don't feel comfortable sailing out in the Neuse River then you could always sail around in Greens Creek... large enough to have fun in but watch out for the crap pots!
I think these guys just had some bad luck... they are experienced sailors and i'm surprised to see this happen to them. I am curious about weather or not the keel clamp was ingaged.
Old 06-30-2008
AboardIndigo's Avatar
Seen Your Mamba
AboardIndigo is on a distinguished road
This really sucked for them - I'm glad everyone's okay. 5 feet of water is about where a C22 swing keel would be bouncing off of the bottom anyway. I'm wondering more if the keel was up or down rather than if the friction bolt was engaged or not.
Regardless, I find mine to be tender. Safe sailing (on a gusty day) on a C22 includes:
  1. Three crib-boards in place and companionway hatch slid shut and latched (top of step is even with waterline if it's coming over the coamings).
  2. Forward hatch dogged down (not possible without aftermarket dogs).
  3. Lazerettes properly sealed and latched (3 sq foot opening into the cabin - don't want one popping open on a knockdown).
  4. Reefed or double-reefed main (biggest contributor to heel).
Anything else in a blow is asking for trouble.
Indigo
1976 Catalina Yachts C-22
Old 06-30-2008
Do the hatchboards have something that prevents them from falling out if the boat inverts??
I drilled a 1/4" hole in the companionway dropboard rail, through the drop board, and into the outer rail and put a pin through the hole, dropboard and into the outer rail to "lock" my dropboards in place in bad weather.
We're Sinking! jhulmer Seamanship 32 11-05-2007 09:33 PM
Aria in Oriental, NC PBzeer General Discussion (sailing related) 10 06-19-2007 06:39 AM
2 Colorado Men Rescued From Sinking Sailboat - TheDenverChannel.com NewsReader News Feeds 0 03-14-2007 11:15 AM
Sinking at the Dock Mark Matthews Seamanship Articles 0 09-23-2003 08:00 PM
Help! We're Sinking! Don Casey Seamanship Articles 0 03-21-2002 07:00 PM
