Old 06-30-2008
papasailor is on a distinguished road
main sail lugs breaking, why?
Here is the history of my sail so anyone who answers can know the background. My boat is a Catalina 30 TRBS. I purchased it in 1996. That same year, I bought a new UK Tape Drive main and genoa. 96 through 03, I raced on Wednesday nights, first in JAM, later in SPIN. I did so so, got a couple 2nd and 3rd place flags and one 1st. Racing was done near shore on Lake Michigan, where the winds are usually light. Aside from racing, my boat is used for very light day sail cruising and mostly sits at the dock collecting bird poo.
The main was always covered when docked. In 2003, downsizing and associated financial issues put me on the hard until this year. All the sails were flaked, in bags and hung in dry storage.
First time out this year, top 5 main lugs broke. Took it to the same sailmaker who sold it to me and he replaced them. After two races (light wind), a couple evening social cruising and yesterday was out in a little heavier wind. Bringing it down, I noticed 3-4 more lugs broken. These are the next down below those which were replaced.
I asked my sailmaker why and he said "it happens". Does it really "happen" like George Carlin used to say? The original main which came with the boat in 1985 still has the original lugs and none are cracked.
Anybody care to comment on why, how, etc?
Old 06-30-2008
artbyjody's Avatar
artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice
Send a message via AIM to artbyjody Send a message via Yahoo to artbyjody
Do you find it difficult to raise the main? It could be - all you need to do is lubricate the guide track... usually, they will break from the force of getting them up (winching), and not usually during sailing. However, if they are during sailing then it could be that the boom is over-tensioned for the wind conditions...
Just some random thoughts on that...
-- Jody
S/V "
1983, Barberis Show 38! or
Old 06-30-2008
Maine Sail's Avatar
If..
If they are plastic slugs than yes this is and can be common as the plastic ages and absorbs UV rays. I've broken a fair number too and they usually start at the top. One way to prevent and minimize them beginning to break is to use a solid SS or Bronze slug at the headboard. Using plastic for the head board slug can lead to multiple slug breaks once the top one lets go. The top headboard slug sees the most load so when it goes it usually takes others with it.
With performance sails and weight concerns many sail makers use plastic all the way up including the head board..??? If you do replace the top slug with metal be sure to keep it lubed with SailKote..
Once one slug breaks you should replace them all. Plastic gets brittle and looses strength with age & UV and these things are under some serious load!!
______
-Maine Sail / CS-36T
Old 06-30-2008
The top slugs also get the most UV exposure, since they are generally in use the most, even when reefed.
Old 07-01-2008
Lubing the track
On an older sailboat, the track had round lugs. To lube this I tied a knot in a rag, sprayed it with T-9 and ran it up and down the track a few times. Yes, I had a pull down on the halyard just in case the rag ripped, plus another light line pinned to the rag.
My Catalina has a tee slot and I'm not sure if rag with a knot would work. Any suggestions other than going up to the top?
Old 07-01-2008
Don't recommend using Boeshield T9 as it can stain the sails and can get gummy and collect dirt. The best and only stuff to use on a mainsail track IMHO is McLUbe Sailcote.
Old 07-01-2008
SEMIJim's Avatar
Last Grumpy Old Sailor
SEMIJim will become famous soon enough SEMIJim will become famous soon enough
I would not use Boeshield T9 on a sail track. It's a good lubricant and protectant for metal, but for plastic and nylon, I think you're better-off with a wax-based lubricant such as Armor All. Or what SD suggests.
Jim
s/v Abracadabra
1976 Pearson P30
Old 07-01-2008
You really don't want to use any type of wax on the slugs, since that will encourage them to pickup dirt as they move. If you really want to protect the slugs, coat them once a month or so with 303 Aerospace Protectant. Keep the track lubed with sailcote... you'll be having much less in the way of problems.
Jim
The Basics of Reefing Mark Matthews Learning to Sail Articles 0 03-29-2004 07:00 PM
Testing Your Sail Trim Knowledge Brian Hancock Seamanship Articles 0 03-27-2003 07:00 PM
