Old 07-12-2008
Sail on Sailors !!!
TheKnapps is on a distinguished road
Send a message via Yahoo to TheKnapps
Do it yourself sanding
We are about to purchase a 1977 Newport 27 and the paint is actually peeling off the boat at the water line. There are very few places in the midwest that does sodablasting, so I was wondering if it ispossible to do it ourselves? Both topside and bottom paint needs to be blasted and repainted. Thanks for your help !!
The Knapps in Missouri
Old 07-12-2008
landlockvasailor's Avatar
landlockvasailor is on a distinguished road
You might want to contact in your area a body shop, they should know someone in the areas that does restoration on cars. If so, one of those guys may have the equipment.
Tom
When I go, let it be by boat, with a steady breeze on the Chesapeake with a bottle of 7-up, a bag of ice, a plastic cup, and a box of wine
Old 07-12-2008
Sail on Sailors !!!
Thanks Tom....Thats a great idea, I never thought of that !!!
The Knapps
Old 07-12-2008
farmboy is on a distinguished road
The auto shop is definitely a good idea. I helped sand an entire Shark24 to the gel coat (topsides and bottom) and it was a tremendous amount of work. Just bear in mind that sandblasting can damage the gel coat. We sandblasted the keel of our boat and sustained minor gel coat damage at the keel/hull interface just from blowback. I would ask around and try to find someone with a reputation for being careful. Also, there are different "grades" of sand, some of which will be easier on your boat than others. I'm sure there are others on these forums that know more about this than I do. You might consider posting in the gear and maintenance section. If you decide to sand by hand, post again and I can tell you our experience. It might be helpful. Good luck
Old 07-12-2008
i would make sure they have experience with vettes using soda
Tom
Interesting Sanding Tool sailingdog Gear & Maintenance 14 04-09-2007 07:38 AM
Sanding off paint in tight spaces sailaway21 Gear & Maintenance 2 03-25-2007 07:53 AM
Wet Sanding dm567 Gear & Maintenance 46 01-03-2007 08:23 AM
wet sanding johnnennis Gear & Maintenance 12 11-05-2006 07:05 PM
Sanding Clear Linear Polyurethane Don Casey Gear and Maintenance Articles 0 02-27-2000 07:00 PM
