Nav Lights for inflatable dinghy's...WTH!!!! - Page 3 - SailNet Community
post #21 of 32 Old 07-15-2008
Any gas-powered dinghy needs lights in Florida.
sander06 is offline
post #22 of 32 Old 07-15-2008
Are you saying that if you used a Torqueedo, you wouldn't need nav lights??? I don't think so.
sailingdog is offline
post #23 of 32 Old 07-15-2008
I'd rather be sailing
labatt's Avatar
Still no responses with a better solution than epoxying on something to the front of the inflatable? We're looking for a solution too...
s/v "Pelican" Passport 40 #076- Finished Cruising - for the moment -
"Don't dream your life, live your dream" - Bob Bitchin'
"I'll see it when I believe it" - Me
labatt is offline
post #24 of 32 Old 07-15-2008
moderate?
camaraderie's Avatar
Well...there's th suction cup mount too...
Portable LED Bow Navigation Light - Suction Cup Mount from Wholesale Marine
camaraderie is offline
post #25 of 32 Old 07-15-2008
christyleigh's Avatar
Originally Posted by merlin2375 View Post
You might try something like this:Portable LED Bow Light
They make both a bow version and stern version with a mount designed for inflatables. You then use epoxy to glue the mount down I believe.
The PO of my boat and dingy glued that round mounting bracket to the outboard at least 5 years ago. I've never even used it but that puts the light up higher and the mount is out of the way whether the light is inserted into the mount or not and secured to a better gluing surface.
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
christyleigh is offline
post #26 of 32 Old 07-15-2008
arbarnhart's Avatar
Originally Posted by camaraderie View Post
Better order several if you are going to stick that on an inflatable and bounce through any chop.
-Andy
Newport 17 - "Kohanna"
At sea Darwin's hypotheses is the final arbiter of right of way.
arbarnhart is offline
post #27 of 32 Old 07-15-2008 Thread Starter
T37Chef's Avatar
To clarify what I was originally trying to say...
I think it is pathetic and unacceptable that these inflatable manufactures, especially one like Avon, do not have the forward thinking to add a useful and proper navigation light support/bracket or a light itself!!!!
I am about to write Avon and tell them just what I think about their inability to even offer it as a option. They could easily, for a small percentage of what the boat cost to build, add either a attachment point for one of those lights like above, or they could install a bow light right on the thing with the ability to easily change out the batteries.
Do they think people don't operate these at night???????? Screw the rules...I want to be seem and identified by others (even if I have joked otherwise in other threads) with a red/green bow light and white all around at the stern that looks like more than an afterthought POS.
Okay, back to regular programming
Shawn
T37Chef is offline
post #28 of 32 Old 07-15-2008
arbarnhart's Avatar
An interesting observation...
My boat is under 7m and my motor pushes it at maybe 5 kts, so I can use an all around while motoring unless under state jurisdiction. Then if I use the sails or scull to move silently I can just use a flashlight as needed, but if I crank up the motor, which provides an audible cue that I am moving about, I have to have proper nav lights. I think the narrow part of the Pamlico, which is fast becoming my favorite haunt, is subject to state regs. I was planning to get lights anyway, but its an interesting note.
-Andy
post #29 of 32 Old 07-15-2008
RAGTIMEDON's Avatar
DON'T ROCK THE BOAT!!!!! You know that if Avon adds a 45 dollar nav light they will raise the price 150 and the west manure version will go up 200!
Don
1980 Endeavour 37 sloop, currently in the Mississippi near St Louis
RAGTIMEDON is offline
post #30 of 32 Old 07-15-2008 Thread Starter
T37Chef's Avatar
Too late Ragtime
Shawn
T37Chef is offline
L.E.D. Masthead Nav. Lights? halcyon13 Gear & Maintenance 2 10-10-2003 12:21 PM
L.E.D. Masthead Nav. Lights? halcyon13 Gear & Maintenance 0 10-09-2003 12:06 PM
Light Lists, Lighthouses, and Visible Ranges Jim Sexton Seamanship Articles 0 06-19-2003 08:00 PM
Light Lists, Lighthouses, and Visible Ranges Jim Sexton Her Sailnet Articles 0 06-19-2003 08:00 PM
Setting Up Your Nav Station Sue & Larry Gear and Maintenance Articles 0 07-26-2002 08:00 PM
