Old 07-31-2008
davidpm's Avatar
davidpm is on a distinguished road
Raising the sail
Is it possible to raise a sail on a boat on land, properly braced with metal stands.
I've got to fix a dutchman system but don't want to tip the boat over.
Old 07-31-2008
max-on's Avatar
1997 Dehler 33
max-on will become famous soon enough
I would not.
Old 07-31-2008
Unless the boat is inside a closed building, I would highly recommend you not do that. If the wind picks, your boat is very likely going to tip...and really bad things will happen to it.
Old 07-31-2008
Plumper's Avatar
Sailor
Plumper is on a distinguished road
It is possible of course. Whether or not you do it depends on the direction the wind is coming from the strength of the wind and whether you can get it down quickly if the wind changes. With a very light wind on the nose and no forecast of anything more I would hoist the main.
There is a tide in the affairs of men,
Which, taken at the flood, leads on to fortune;
Omitted, all the voyage of their life
Is bound in shallows and in miseries.
Shakespeare, Julius Caesar IV, iii, 217
Old 08-01-2008
nolatom will become famous soon enough
You have two opinions above. Both are right.
It all depends on the conditions.
I wouldn't do it with just metal stands holding the hull. The wind is much stronger than you think. Whatever you want to test, do it in the water. That's what the sailmakers, and the hull designers, designed their product for.
Old 08-01-2008
Banshi's Avatar
Banshi is on a distinguished road
I would only do it if I knew that if it blew over it would not damage anything around it, power lines, other people boats, a house and so on. I would then pick a day with a light wind forecast and do it early in the morning. I would put four screw in trailer tie downs at the corners and lash it down for some added stability and work real fast.
I did mine but it is fairly small with a mast short of 30 ft and sitting on a trailer with a solid base.
1976 Chrysler 22 "CinJam"
Old 08-01-2008
chucklesR's Avatar
Gemini 105Mc Hull 987
chucklesR is a jewel in the rough chucklesR is a jewel in the rough chucklesR is a jewel in the rough
one word: unsheeted
If you prefer: luffing
Old 08-01-2008
JohnRPollard's Avatar
Moderator
I wouldn't risk raising the mainsail while on jackstands.
What's the trouble with your Dutchman system? Maybe we can suggest an alternative approach. I'm having trouble coming up with a Dutchman problem whose remedy would require raising the main while on the hard??
Old 08-01-2008
davidpm's Avatar
The lines are broken and need to be replaced.
I can just thread the new lines and check their tension when the boat is in the water. Your right not worth the risk raising the sail.
Old 08-01-2008
Moderator
Yeah, that's the way to do it.
I've found that you actually have to load up the sail (drop the topping lift, sheet in, etc) to get the tension set correctly on the monofilament. If you only set it with the topping lift holding the boom up, and the sail unsheeted, it's hard to guess the exact amount of slack necessary for unimpeded sailing.
Trimming Your Asymmetrical Spinnaker sandygoodall Seamanship Articles 14 03-31-2010 09:27 AM
Heavy weather sailing sailorfrank Learning to Sail 18 08-24-2009 01:24 PM
Sloop, Cutter or Ketch jsgsail Boat Review and Purchase Forum 17 12-26-2008 02:47 PM
Headsail Reefing Basics Brian Hancock Gear and Maintenance Articles 0 08-05-2004 08:00 PM
The Basics of Reefing Mark Matthews Gear and Maintenance Articles 0 03-29-2004 07:00 PM
