08-05-2008
Not a bad reason to carry a spare, transom pulpit mounted emergency antenna with a cable long enough to reach the main VHF as another backup. I have one.
Originally Posted by RAGTIMEDON
Be thankful it was the Butterfly and not Distant Star! I had a friend lose his mast on a Bristol - I think she was 28 feet. Had a leak around the chain plates, which were bolted to a bulkhead inside. Said bulkhead had thin glass coating over plywood, the ply rotted unseen and the glass was too thin to hold the force. When the chainplate ripped out while he was on the river, there was a towboat with 900 feet of barges less than half a mile away bearing down on him at 5 knots. Good fortune that there was another sailor nearby, because he couldn't call on his radio - Antenna on masthead underwater! He couldn't run the engine with shrouds, stays, sails in the water! No time to paddle with towboat approaching - It can take 3/4 mile to stop those things! A friend in a 34 CaboRico radioed the towboat, then towed the Bristol out of the channel. Things like that happen, and PWC idiots keep deliberately driving close to barges! Scarey! That's why I have flares and a handheld radio; my main radio has a masthead antenna, too.
