Old 08-15-2008
AllThumbs's Avatar
midlife crisis member
AllThumbs is on a distinguished road
Mainsail help
The main on my 15 foot boat has a chord in the luff which goes in the groove of the mast. It seems like this chord has shrunk causing the sail to be wrinkled at the luff. It also makes it a lot harder to raise since the wrinkles make it a tighter fit in the mast. If I lay the sail out on the grass I can definately see that the luff is short and it won't let the sail lie flat. I guess I am wondering if this is normal (done on purpose) or if the rope has indeed shrunk. The sail is stitched thru the chord so the only way to fix would be to remove the stitches, pull it thru, add some rope and restitch. Is it worth it and would using it as is degrade performance? I would estimate the luff would be 6" longer if repaired.
Thanks, Eric
Old 08-15-2008
pfatyol's Avatar
Swansea, MA
pfatyol is on a distinguished road
Are you sure that the cord has shrunk and that the sail has not streched / been blown out, Loosing it's built in shape? I would look at how old the sail is and have a loft do a check out on the main.
Good luck
Patrick
S/V "Fat-Kat"
C&C 32, Hull #237
Mt. Hope Bay
Old 08-15-2008
AllThumbs's Avatar
According to the PO, the sail is 5 yrs old. Been used for 3 of those years, a couple times a week for a couple hours each time during the summer months.
Should a sail have shape of should it lie perfectly flat on the floor?
Eric
Old 08-15-2008
pfatyol's Avatar
Swansea, MA
Short answer no, That's part of the reason to have a it checked a a loft. They will double check the shape, check the stiching, clean and overall evalute the sail for you. My main has slugs, I have not used a bolt rope sail in about 20 years now. But I am a firm believer in having the loft check my sails yearly, I consider it mandatory maintenance on my boat.
Patrick
S/V "Fat-Kat"
C&C 32, Hull #237
Mt. Hope Bay
Old 08-15-2008
jgeissinger is on a distinguished road
Rope luff
Many small boats, such as my Lido 14 and others do use bolt ropes on the main. Among my sails is an old set on which the rope luff has indeed shrunk. I can get rid of most of the problem simply by really applying a lot of force to the main halyard when hoisting. The main halyard should be rod tight even on a small boat like that. You are not going to hurt anything by trying, and if it doesn't work, take the advice already given you. A sailmaker can put in a new rope luff quickly and inexpensively.
Old 08-15-2008
Rope luff (cont.)
Forgot to add: No, the sail should not lay flat on the floor. Yes it does have shape built in to it.
Old 08-15-2008
AllThumbs's Avatar
Thanks for the advice. I will get the sail checked out this winter.
Eric
Old 08-15-2008
AllThumbs's Avatar
Maybe I can get the dude to add slugs at the same time. I hate how much effort it takes to hoist and drop the main.
Eric
Old 08-15-2008
An excellent idea. Get metal slugs if you can...they are more UV-resistant than the plastic ones...
Eric
Old 08-15-2008
SVDistantStar's Avatar
'72 Pearson 36
SVDistantStar is on a distinguished road
Send a message via AIM to SVDistantStar
Ive been thinking of having a new main made for the Butterfly. Currently it has a bolt rope, im considering when i have the new sail made to have slugs installed. Any advantage with slugs over the bolt rope?
1972 Pearson 36 S.V. Distant Star
Fine-Tuning the Autopilot, Part Two Dan Neri Gear and Maintenance Articles 0 10-13-2003 08:00 PM
Upgrading Your Mainsail System Sue & Larry Her Sailnet Articles 0 11-17-2002 07:00 PM
Basic Mainsail Trim for Racers, Part Two Pete Colby Racing Articles 0 12-02-2001 07:00 PM
Mainsail Controls for Performance Dan Dickison Gear and Maintenance Articles 0 07-04-2001 08:00 PM
Mainsail Controls for Performance Dan Dickison Racing Articles 0 07-04-2001 08:00 PM
