Jacklines - Page 5 - SailNet Community
post #41 of 45 Old 08-26-2008
It depends on how the padeyes are mounted. If they're screwed to the fiberglass... no... if they're through-bolted with fairly large bolts (say three 1/4-20 bolts) and have a backing plate and such, yes, they probably are.
Originally Posted by welshwind View Post
Are padeyes strong enough to serve as termination points for jacklines? The point about the aft cleats is well-taken and I have padeyes toward the centerline of the boat near the stern.
sailingdog is offline
post #42 of 45 Old 08-26-2008
Xosh's Avatar
Climbing webbing will be just fine if that's what you want to use. Tack on the "marine" label and pay out as arse. I used do a lot of rigging and the climbing webbing is more that sufficient to take the weight.
I've set up numerous slacklines (a tightrope of sorts made from 1" climbing webbing) on a 60' gap with a one inch piece of tubular climbing webbing threaded with another section of 3/8" webbing. The tension on the webbing was so great that in the center of 60' there was less than 2' of sag. I took numerous falls (aprox. 7'-9' drops) Shockloading the line under extreme tension. I'm still here to tell the story and if your in a chest harness taking that much force from waves, etc..you're going to get ripped in half.
Just my .2 cents
~Josh
Xosh is offline
post #43 of 45 Old 08-26-2008
And if you are wearing an inflatable and hit the water, it is going to inflate, even while you are still tethered, adding drag and making getting back on deck a lot harder. Better to run the jacklines to prevent a fall outside the lifelines.
If over the side, climbing up can be impossible due to height or water movement, so a plan, made in advance, to get around to the stern is advisable. That needs to be considered: if the jack lines are set up to allow a person to go over, they must allow the person to get around to the relative calm astern, and hopefully a boarding ladder or platform.
allendick is offline
post #44 of 45 Old 08-27-2008
Which brings up the question of how to get the tether to slide past the stantion tops.
Gashmore is offline
post #45 of 45 Old 08-27-2008
You'll find you instantly have superhuman strength, but not necessarily superhuman reasoning.
The second comment in post #44 was in regard falling over when not necessarily tethered, but also applies when tethered.
The first was pointing out that if the tether lets you fall over or through/under the lines -- which it should not but most do -- then getting back up may be impossible without strong assistance or a way to work your way back to a platform, ladder, or line and loop hanging over for such an eventuality.
Getting a tether by a stanchion may be a big problem or it may not, depending on the tack, waves, boatspeed, etc., however having two tethers makes it a whole lot less risky, since one can be detached and moved at a time. Of course with two tethers, the risk of going over should be much less in the first place.
Don't ask me how I know this.
Also, netting or weaving in the lifelines may look a little tacky, but it has saved many a dog, child, or adult sailor from an unscheduled swim after slipping or tripping and rolling under the lines.
Safety Equipment for Offshore Sailing PracticalSailor Gear and Maintenance Articles 35 09-11-2014 02:32 PM
roll your own tethers janders Gear & Maintenance 33 08-19-2008 04:23 PM
1st Time Singlehanding JSL3 General Discussion (sailing related) 61 07-22-2008 10:13 PM
how to on jacklines capt.stu Gear & Maintenance 18 03-08-2008 12:57 PM
Safety Essentials John Rousmaniere Seamanship Articles 0 12-07-2000 07:00 PM
