08-17-2008
Owner, Green Bay Packers
It'll probably work fine without bending as you're not going to put that much strain on it just keeping the clew poled out. In light air for shorter runs you may find that a crew member can just sit there casually holding it in position. Given that it's a boat hook I wouldn't spend too much effort in creating any kind of a mounting bracket, although most whisker poles use a padeye mounted on the mast and you could probably order one of those from Forespar conveniently in the size for your future whisker pole. Otherwise you can just lash it to the mast temporary and use some small stuff to tie it to the clew of the sail. You can just cut the small stuff away then when unrigging.
Wm. F. Buckley, Jr.
