09-03-2008
If you're planning on eventually documenting the boat anyways, it would probably make sense to do it now...since the cost for documentation is a one time cost, and will probably go up in the future, not down. Re-newing the documentation, once you've done it is very easy...simply faxing a form into the USCG...
