Old 09-04-2008
davidpm's Avatar
davidpm is on a distinguished road
Edison Pedestal lock knob
Just did a 70 mile sail without autohelm.
I notice that I could balance the helm for a few minutes if I tighten the locking screw on the helm.
This way I could correct a few inches every minute or two and not have a hand on the wheel all the time.
Does this "trick" wear out something inside the steering column?
Bad Idea?
Old 09-04-2008
Banshi's Avatar
Banshi is on a distinguished road
I could eventually but they sell rebuild kits for that when and if it eventually stops holding.
1976 Chrysler 22 "CinJam"
Old 09-04-2008
SVCarolena's Avatar
Pearson 303
SVCarolena is on a distinguished road
We do the same thing on our boat. The only part that wears is the two friction pads around the shaft on which the wheel is mounted, which are pushed into the shaft when you tighten the lock knob. This is inside the pedistal and it looks like a miniature version of drum brake pads on car or truck. As already stated, Edson sells repair kits that include the pads. However, I think it would take a very long time for them to wear out. We've also found that if we are feeling lazy and the winds aren't too strong, we can just let the boat go and it will self steer when we are on a reach to close hauled, turning into the wind with the puffs and off the wind in the lulls. The slight deviations in each direction tend to cancel one another out over time, keeping us generally on course. I know it isn't the most efficent or fastest way to get to our destination, but it seems to be a good lazy-man's autopilot when we aren't in any hurry.
Old 09-04-2008
christyleigh's Avatar
christyleigh is on a distinguished road
You are OK as long as you completely release and tighten down hard. I wore out a set of "brake pads" in one season by not completely releasing them.
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
Old 09-04-2008
PalmettoSailor will become famous soon enough
Has anyone done the replacement? The pads on our new to us C36 are pretty well completely shot and I need to do the replacement. Of course Edson is charging close to $50 for 2 rubber pads, a cotter pin and some glue.
I was wondering if anyone has devised a lower cost alternative. I have some rubber strips of various thicknesses left over from a home project. I may try "relining" the brake with homemade pads rather than pay 10 times what the materials are worth.
PalmettoSailor (formerly midlifesailor)
s/v Palmetto Moon
1991 Catalina 36
Navigating locks GoodOldBoat Good Old Boat 9 1 Day Ago 01:46 PM
I need a knob for a GPS mounting arm Quickstep192 Gear & Maintenance 9 09-11-2008 07:23 AM
Traveling the Champlain Canal labatt General Discussion (sailing related) 6 04-09-2008 01:37 PM
Maintenance question: pedestal lubrication FrankLanger Gear & Maintenance 3 07-10-2007 05:53 PM
Bristol 29.9 pedestal cover? annenash Bristol 0 11-30-2006 03:49 PM
