Old 09-04-2008
SVDistantStar's Avatar
'72 Pearson 36
SVDistantStar is on a distinguished road
Send a message via AIM to SVDistantStar
What to do if your anchor is hung up on cables?
Well i lost one of my new Oceane anchors today. It was hung up on 4 large cables that i believe to be power or phone cables as they were humming. I didn't lose that anchor for any lack of trying to save it.
Today was my day for moving the boat from the anchorage to a creek near my home for the rest of winter. We must have spent 2 hours trying to get the anchor back. After winching it up useing the sheet winches with the rode ran over one of my mast winches we found it was hung up on cables of some sort. I got the anchor to about 4' of the surface, but that was it. After getting in the water and figureing out what was going on, i decided to try attaching a trip line to the hole in the anchor for one. After winching the trip line to try lose the cables, they just hung on. Figure maybe i could remove the chain from the rope and maybe get it up that way. Got the chain loose and started winching on the trip line again and the trip line gave. Goodbye anchor....
Oh yea, i had a line around the cables but for some reason had it just laying on deck and not attached.
What would you have done?
1972 Pearson 36 S.V. Distant Star
Old 09-04-2008
wasn't the chart marked for the cables????
use a stronger trip line in the future.
Old 09-04-2008
'72 Pearson 36
Nothing on the chart, this is an anchorage. I was in the big anchorage right across from Charleston City Marina.
Heres a warning for anyone in that area, dont anchor between the CM bath house and the range marker. I was pretty much right between them. On another note, if you do anchor there and happen to pull up a 38# Oceane anchor with 15' of rusty chain, let me know, ill pay a reward. Also watch out in that area, theres a big glob of old rusty steel cables from a crane or something that was hung up on my other anchor.
Old 09-04-2008
Hawkeye25 is on a distinguished road
If you can get a line around the cables and secure each end to your bow cleats, you then drop the anchor and use an oar or boat hook to knock it free.
With multiple cables, use a boathook to slither a dockline through one cable at a time, freeing it and dropping it.
Never do anything around any cables you suspect of being electrical without gloves. Never drop your connection to your anchor unless you have already accepted it as lost. Always consider a lost anchor as the perfect time to upgrade. For your boat, a 45 lb Spade and 200 ft of 5/16 BBB chain with a dual direction windlass. Oh, yeah. . . . . Just a thought.
Old 09-04-2008
artbyjody's Avatar
artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice
Send a message via AIM to artbyjody Send a message via Yahoo to artbyjody
What was the depth - could you have actually dived to get it - not like Charleston Water temps are like PNW - you ha it to four foot - you could of dove it maybe.. otherwise cut and let lesson lie..
-- Jody
S/V "
1983, Barberis Show 38! or
Old 09-04-2008
Stillraining's Avatar
Handsome devil
Stillraining is a jewel in the rough Stillraining is a jewel in the rough Stillraining is a jewel in the rough
Bummer dude..Phone lines dont hum..Consider your self Fortunate you didnt get fried and the loss of a couple hundred wont hurt as bad..
I would report it to the Harbor master..I should think it illegal to have cabel crossings unmarked in this day and age..If so Id be after whom ever ownes the cabled to replace my anchor...That was a 45lb Ronca wasent it?...
Old 09-05-2008
Omatako's Avatar
Omatako will become famous soon enough
If I hooked into cables I wouldn't tell anybody, not ANYBODY. There was a luckless fellow here in NZ some time ago who hooked a primary international comms cable and "tore it up a little". I understand it cost him many thousands of dollars to have it properly lifted, restored and relocated.
The Coast Guard here warn that if the vessel that performs the lift-out of the cable for repairs happens to be in Fiji or somewhere similar, they will charge you to bring the vessel back to do the resoration job and that could run into hundreds of thousands of $$.
Maybe they're just trying to scare us but hey, why take the chance? If I accidentally hooked such a cable, I'd wait to hear the result on the news!!
Andre
Old 09-05-2008
Karletto's Avatar
Karletto is on a distinguished road
probably the best thing would be to call a free diver/ scuba diver, coast guard or police. next technique is to tie a fender to anchor rope and go for help with the boat. but buzzing cable not signed on a chart + who will mess with it? it's not goodbye anchor -> call in local diving clubs/ police and find out if someone is prepared to save it
Old 09-05-2008
IMHO, and i believe the law supports this as well, since the area wasn't marked as off-limits to anchoring, or at least that would appear to be the case, and the cable wasn't marked on the charts, the company would have very little recourse if SVDS damaged the cables. He did nothing wrong.
IMHO, the harbor master and USCG should be notified of the cables, if for no other reason, to update the charts and prevent someone from cutting into the humming cables by accident in the future.
BTW, I wouldn't go diving near humming cables...any leakage of AC current could kill you stone cold dead before you knew it was happening.
Andre
Old 09-05-2008
philsboat's Avatar
philsboat is on a distinguished road
If it was near the surface I would have put a small float on a line and pushed the float under the cable with a boat pole,then tied off both ends of that line on deck.Now lower the anchor untill it is free and then release the line holding the cable.
Underwater electric cables are well protected with aluminum sheath and plastic covering over that.If there was any damage to the cable I might cut the anchor free to avoid any risk of shock.
Phil
steering cables HarbourBoy Gear & Maintenance 8 12-11-2007 10:20 PM
Electric Cables in the mast..... AquaVitae Gear & Maintenance 3 03-07-2007 05:05 PM
Sailing Instrument cables extensions? ref_123 Gear & Maintenance 0 05-24-2003 07:46 PM
Clanking Cables Inside My Mast frankmitchell Gear & Maintenance 5 04-11-2002 07:42 AM
replacing morse cables? admiraltyr General Discussion (sailing related) 1 07-16-2001 04:52 AM
