New Sails - Page 2 - SailNet Community
post #11 of 13 Old 11-10-2008
If you have a fairly common boat, with well-known rig measurements... using a "internet" discount sail loft makes sense... but if your boat is less well known, less common, or custom, then using a local sail loft has major advantages.
sailingdog is offline
post #12 of 13 Old 11-10-2008
woodshole's Avatar
I have found that with cruising sails I am more price sensitive because at the end of the day the sail sits on a roller furler in the elements. When I know a sail will be used infrequently and not beat upon I am more willing to spend the extra 20%. I bought a beautiful light #1 seven years ago from North and it is still a spectacular sail but it is used rarely while the #2 I use most often was relatively inexpensive and I don't have to stress about it. Cheers!
woodshole is offline
post #13 of 13 Old 08-10-2013
Smile Re: New Sails
Hi,
I bought a set of 3 sails from Fareastsails - a main, a 135 Genoa and a Gennaker. They arrived in April. Have used them now for 4 months and all is well and good. I did not order a spinnaker sock and I think I should have. I have seen several Gennaker Furlers and they seem to work different.
The fellow at Fareastsails said that there were 2 type of these - one furls on its own luff and the other uses a torsion line.
All in all I am happy, it took 4 weeks to make the sails - they said March - April are busy season. I would buy from them again.
Jack Shiler is offline
My First Boat...Boat Term Question... Kacper General Discussion (sailing related) 38 09-23-2008 06:52 PM
The Balance of Hull and Sails Steve Colgate Seamanship Articles 0 05-25-2000 08:00 PM
The Balance of Hull and Sails Steve Colgate Buying a Boat Articles 0 05-25-2000 08:00 PM
