Difficulty in coming about - SailNet Community
post #1 of 11 Old 09-07-2008 Thread Starter
I sail on the Columbia River about 35 miles north of Portland, OR. It's fairly narrow there so there's lots of coming about. I recently bought a Lancer 25 and haven't sailed for about 4 years on boats that were larger and smaller but never had a real problem before. I understand that because of the 3/4 lenght shoal draft keel that it doesn't point as well but maybe I'm doing something wrong when it coems to coming about.
I point as high as I can and get as much speed as I can, hard over on the tiller and don't pull the jib over until it backwinds. The problem is, it's a bear to get it to backwind. most of the time I go into irons and have to wear ship (go all the way around) in order to bring the sails to the other side.
Any info or help in what I'm doing wrong would be greatly appreciated.
Harris
Survivor is offline
post #2 of 11 Old 09-07-2008
Harris,
Most likely, your problem is boat speed....i.e., lack of sufficient boat speed.
Instead of "pointing as high as you can", the preferred way for many boats is to fall off a bit to ensure that your sails are full and gain maximum boat speed. In very light airs, you may have to fall off quite a bit to do this.
Bill
btrayfors is offline
post #3 of 11 Old 09-07-2008
Wandering Aimlessly
PBzeer's Avatar
I second that advice.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
PBzeer is offline
post #4 of 11 Old 09-07-2008
Harris, what kind of boatspeed and wind speed are you talking about?
I don't know the Lancer but rig tuning (proper mast rake and spreader length) can also make a big difference in pointing ability on any boat. As will sail trim & condition, of course.
hellosailor is offline
post #5 of 11 Old 09-07-2008
Freesail99's Avatar
I'm sure that river currents are a factor also. They are on the Delaware.
S/V Scheherazade
Freesail99 is offline
post #6 of 11 Old 09-07-2008
Hey Harris, You may just need some more bonding with the new boat....BTW, congrats on the boat.
First, it sounds like you may be sailing a little close to the wind just before a tack. Just before you tack, fall off the wind just a tad to build more speed. Your tiller movement should be smooth but not too quickly as to stall the rudder thus slowing the boat. You might also try easing or loosing the leeward jib/genoa sheet as the sail starts to luff during the tack and when it reaches the center line of the boat, go ahead and help it cross by sheeting in the new leeward sheet. Might help to pull the bow through the tack sooner by getting it to draw a little quicker.
Another consideration is the sails themselves. Sails that have too deep of a pocket(blown out), are not going to be very efficient upwind thus giving up the power and speed needed to get you through the tack.
My appologies if I've over simplified...and enjoy the new boat.
Bob
fullkeel7 is offline
post #7 of 11 Old 09-07-2008
Cruiser/Lats and Atts TV
Moonfish's Avatar
I learned to sail on the Columbia at Portland in a Newport 28. Typically coming about was no problem (it was a fin keel). On my Gulf 40, with a cutaway full keel, when I was hard on the wind I would loosen the reigns a bit and crack off a little just to pick up more speed - then tack.
"Always approach the dock at the speed you wish to hit it."
s/v VENUS
1978 North Sea 33 Pilothouse Cutter (Ta Chiao)
Moonfish is offline
post #8 of 11 Old 09-07-2008
Seinor Member
capn_dave's Avatar
Cool Ahoy Moonfish
You mentioned you were throwing the rudder hard over. Don't do that either. When the rudder is all the way over it acts like a brake. Sure the boat will turn, but slow down fast.
Try to go easy with the tiller and everything else the crew told ya.,
Fair Winds
Cap'n Dave
capn_dave is offline
post #9 of 11 Old 09-07-2008
I'd second getting the boat speed up by falling off a bit, since you need the momentum to carry you through the eye of the wind. I'd also second the idea that you need to turn more smoothly, since you don't want the rudder killing what momentum you've gotten built up.
sailingdog is offline
post #10 of 11 Old 09-09-2008
Lifelong Sailor
jtull7's Avatar
I agree with bratfors.
jtull7 is offline
That stupid metal pipe coming out the side of my camp stove jimmiebuchanan Gear & Maintenance 13 10-21-2007 08:35 PM
Club Marine Boat Show coming to Waterfront City - Sail World NewsReader News Feeds 0 02-22-2007 09:27 AM
Race day gives fans a reason to keep coming back - Port Huron Times Herald NewsReader News Feeds 0 07-18-2006 08:15 AM
Coming Soon… @ Live Sail Die NewsReader News Feeds 0 04-08-2006 07:15 PM
