I just measured the J value, from the front of the mast steep to the tip of the bow is a whooping nine feet! I know, I know most of you have little experience on a boat as fine and large as this!
The jib measures in at a massive nine feet nine inches. So I'm thinking it should run inside the stays?
I think I'm safe using PVC as I never see a "Rayray" bird? I googled it and this was all I could find?
I think the Rayray bird and parasites it hosts (Morpions) are an upper class epidemic? Or may hap it's just to cold here? (The wiki info on Rayrays and morpions says they like warm climates and crappy boats, So I'm in the clear)
Thanks for the laughs and info.
Cope
Wiki first aid for ridding your self of Morpions.
Steep one, Shave a one inch square area of short and curlys.
Steep two, cover affected area in gasoline. (petrol for you non USA guys)
Steep three, Locate one BBQ fork (The two prong type are best)
Steep four, light Gas (petrol) with match.
Steep five, Stab Morpions with BBQ fork when they run to the one by one inch clearing.
Good luck!
Cope.
