Jib sheets, In or Out?? - SailNet Community
Blogs
Old 09-20-2008
Cope44's Avatar
Censored4 your protection
Cope44 is on a distinguished road
Question Jib sheets, In or Out??
Hello again folks.
My question is should the jib sheets be run inside the stays or out side?
On my last sail I ran the sheets on the outside, the sheath was damaged and the line seemed to hang up on every tack. With the sheet ran on the inside of the stays it seems the jib will rub on the stays causing damage to it.
The boat is a 21' Clipper Marine. (Please don't move this to the orphan boats section, I have had a post there for a week with no responses. I think thats where post go to die?)
Here is a pick of the sheet position.
Thanks for the help.
Cope
CM 21 #291
I fight to refuse a battle of wits against a one armed man.
Old 09-20-2008
run on outside.
You can get PVC tube and cover the shrouds so they don't schaffe the sheets.
Several speciality houses sell a tube that is slotted along all its lenght so you can put it around the shrouds.
Hope it helps..
In the mean time I am locating the tube I refer to.
Edit...HERE YOU GO ...go buy a few feet of this and tell everyone uncle Giu sent you....
Old 09-20-2008
Cope44's Avatar
Thanks!
Thanks for the answer.
I will continue to run the sheets outside the stays. (+ add some pipe to cover the rigging.)
I know this is not the right thread, But I would like to thank you for the "learn to sail vids". You have a beautiful boat and family, and inspire more than you will ever know.
Thanks again, and keep doing what you do so well.
Cope
CM 21 #291
Old 09-20-2008
You're welcome.
By the way..I really really love your avatar...
When I was young and couldn't afford much, we used tygon tubing or small diameter hose on the shrouds. Not as pretty but does the same job.
On the bottom, to cover the turnbuckles use a larger diameter pipe or tube.
Alex
Old 09-21-2008
chipdance is on a distinguished road
I'm still very new to sailing, my first sail was on my first boat (1979 MacGregor Venture 25) which I bought about 4 weeks ago. On my boat there are some rope locks (the pinch kind, not cleats, proper name?) located to the outside and back of the cabin. There are three on each side. they are labeled and include one on each side for "jib sheet". I don't have a rolling furler, so when using my "storm jib" (approx 70%) the sheets seem to naturally run on the inside of the stays almost straight back to the "locks". The boat has had many mods so I am not sure if these locks are stock but it seems to be a good fit. When using the larger jib (genoa? about 130%) I find those locks not very useful because of the angle from the clew to the locks around either the outside or the inside of the stays. Does anyone have any thoughts about my particular setup? Are the locks stock? Is it a bad idea to run the sheets inside of the stays when using the storm jib?
Thanks
Chip
1979 Mac Venture 25 "Chinook"
Old 09-21-2008
SEMIJim's Avatar
Last Grumpy Old Sailor
SEMIJim will become famous soon enough SEMIJim will become famous soon enough
I think you're referring to clutches. Do they look kind of like something on this page?
Can't answer any of your other questions, as I've no idea what a MacGregor 25 even looks like.
Jim
s/v Abracadabra
1976 Pearson P30
Old 09-21-2008
SemiJim-
I think he's talking about either cam cleats or clam cleats, depending on whether the pinch is cause by pulling the rope into the slot or the cams "pinching" the rope.
Cam Cleat:
Clam Cleat:
Old 09-21-2008
eMKay's Avatar
eMKay is on a distinguished road
On my boat, jib inside, genoa outside.
Siren 17 #1094 "Minuet" (first boat)
O'day 192 #488 "Aria" (second boat)
Hobie Wave #2697 (current boat)
Hunter 27 #716 "Revival" (current boat)
Old 09-21-2008
Sheeting inside or outside usually depends on the location of the jib/genoa tracks, the deck plan, and the sail itself.
The OP's picture looks like a situation that, with added tracks inboard, the working jib could possibly be sheeted inside. Any overlapping sail, of course, goes outside.
Chipdance: From your description it sounds like you are missing a step. The sheet should not go directly to your clutches/cleats, but through at least a padeye or a block on the cabin top or deck first.
From the pics in this link:
Gallery :: Venture 25
It looks like there's a short track and block on the coaming leading to a winch, and any cabintop cleats/clutches look to be for halyards run aft.
Though the boat is apart, these pictures may be helpful to you.
1984 Fast/Nicholson 345
Old 09-21-2008
Cope44's Avatar
Giu ,Thanks for the complement on my avatar. It makes me smile to think of someone like you (Sailnet guru, master cruiser, and bad a$$ boat owner) with little money and "just starting out". You truly are an inspiration to a novice sailor, in a little old boat, on a lake.
Jib track?
This is looking down the rail. The chain plate is kinda hidden by the glare off the truck windshield. When I look at it from this angle it seems the line might run from the jib track around the stay and then to the sail. (causing excess friction)
How dangerous would it be to step the mast and hoist the jib while on the trailer? If I don't belay the jib sheet it should be fine right?
what about using a "pennant" to raise the jib over the bow rail? How can I combat the pennant moving the jib to far back towards the mast?
Pennant pick
As always thanks for everyones time and advice.
Cope
CM 21 #291
Sailing Basics Steve Colgate Learning to Sail Articles 0 03-09-2003 08:00 PM
Sailing Basics Steve Colgate Seamanship Articles 0 03-09-2003 08:00 PM
Sailing Basics Steve Colgate Her Sailnet Articles 0 03-09-2003 08:00 PM
Sail Trim Steve Colgate Learning to Sail Articles 0 05-10-2000 09:00 PM
Sail Trim Steve Colgate Gear and Maintenance Articles 0 05-10-2000 09:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
