Big Freakin' Sails - Page 105 - SailNet Community
 515Likes
post #1041 of 3274 Old 03-18-2009
blt2ski's Avatar
The CYC Center Sound Series started by Mordacious. A few minutes ago it was about 10-15 post down in the upper sailing thread area.
CYC Center Sound Series - Sailing Anarchy Forums
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #1042 of 3274 Old 03-18-2009
Erps—
Usually it is Those who have gone aground and those who lie about it...
Originally Posted by erps View Post
I feel for you Jody. On the bright side, you've joined a new club, as there are two types of boaters, those that have gone aground and those that haven't gone aground yet.
It looks like the damage is the the fiberglass fairing?
sailingdog is offline
post #1043 of 3274 Old 03-18-2009
blt2ski's Avatar
I'm also recalling a YC in London? no dues, you get in by initiation only! it was started by two bigger big wig sailors in London as I recall. Do not recall the actual name, but it is for folks that have "GOOD groundings" of there boats. I would Jody and Jam the other boat that grounded last saturday qualify for membership!
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #1044 of 3274 Old 03-18-2009
Erps—
I don't lie about it. I have only be aground__________times!
Never Forgotten
bubb2 is offline
post #1045 of 3274 Old 03-18-2009
artbyjody's Avatar
Well, damage is definitely a bit (a lot) more intensive now. I arrived early this morning, to meet the surveyor and was greeted by "HG" with a pool of oil mixed with water at the bottom of the keel. So, that definitely confirmed that the damage is a bit more extensive (a keel bolt is loose). Due the framing structure that supports the keel - it will be a very costly job. The interior will have to be removed, keel will have to be dropped, re-faired, etc...
However, the positive side to all this is: if this doesn't become a salvage boat, I'll have plenty of time to do properly do all the interior varnish work and install a new bilge system properly.
Everyone seems to think it is doable (always that false hope / negotiation deal) but no one will really know until the sub flooring (it is glassed in / over the fiberglass framing that runs parallel to the steel framing the keel is attached to) is removed, water / oil pumped out, and they can assess how it is all attached and what is damaged structurally. Probably will be a good week or so before I know where we get to go with this. However, the surveyor did mention to me that we did the right thing. Had the boat been allowed to take on water (from the listing after becoming aground), it would of been a loss from the word go.
-- Jody
S/V "
1983, Barberis Show 38! or
artbyjody is offline
post #1046 of 3274 Old 03-18-2009
On the hard
CharlieCobra's Avatar
That would have been a real shame, especially considering the rarity of HG. I mean, Oh Joy is a one of a kind custom build but there were at least 6 Knutson yawls built.
CharlieCobra is offline
post #1047 of 3274 Old 03-18-2009
GeorgeB's Avatar
Blt2ski – I’m glad that your boom is well on its way to repair and not so expensive. I’m assuming that they are sending you a blank and that you will be doing all the remounting. At least that way you will get it done right and make any necessary improvements to the original, “stock” spar. If I can make a suggestion/ Use Teffgel (not Tuffgel) to mount your hardware. Tuffgel will act as a lubricant under vibration and you may find your screws unexpectantly backing themselves out (We found out the hardway on the PacCup when our mast t-track started to work itself loose). The Teffgel has just enough adhesive to lock but not enough to seize up. Sort of like blue lock tight which will also isolate dissimilar metals. I’m no longer a fan of lanocote as it is messy and it will ooze out when warmed by the sun. My little sail repair will set me back some $150 so you are indeed fortunate.
Artbyjody – sorry to hear of your travails. As you know by now, you will get no compassion or understanding by the posters at SA. Their bravura is entertaining to read and sometimes you find a pearl of wisdom. But their site is all about trash talk which is ironic insomuch that they are constantly complaining that racing is dying and they can’t figure out how to attract more participation. Go figure. If those guys were on the Sea of Galilee when Jesus walked on the water, they’d probably complain that he did so because he couldn’t swim.
I, for one, am interested in your story, but, not being from the area, am a little confused as to some of the details. Could you make a little sketch or something? Was this a windward mark where you were changing course to a reaching leg? And where was the shoal in relation to the mark? I’m assuming that you called it in to vessel assist and that they were several hours away. Did you try to use your anchor to check your drift? And please, go over again how you were able to keep the boat upright when the tide was at its lowest. You might want to consider writing up your incident in detail and submitting it to Sail magazine’s “Voice of Experience” feature. I’m sure that many other people will want to learn from your experience. I wish for you a speedy repair and that Hello Gorgeous comes back better than ever.
Smack – As you probably figured out by now, broken boats sail real slow and they are expensive to repair. And money spent on repairs is not being spent on improvements and new gear. A couple hundred dollars of repairs after each race is the price of a new spinnaker for me at the end of the season. Besides, my wife says I’m just one big disaster away from retiring from racing so I gotta play it cool. And, when are you coming out to the Bay Area? I want to show you what sailing in real salt water and in real wind is all about.
GeorgeB is offline
post #1048 of 3274 Old 03-18-2009
blt2ski's Avatar
George,
Believe it or not, that is complete! per original specs, by the spar manufacture! along with a new gooseneck for the $425-450. I have a pretty small 10' boom and actual spar.
Hopefully it will get from Fl to up here by the end of next week. All I will then have to do is mount the pulleys, sheaves etc for the main sheet, run the lines for out haul and 2 reefs, take off and mount a new gooseneck. Altho if everything shows up friday, I may mount the boom on current gooseneck, and redo the gooseneck sunday. Looks like I may have a full 6 person crew which makes things easier on my boat instead of the 4 the last two weeks.
I'll agree on the repair part. Been pretty luck so far, but a new code 5 spin and pole is on the list of improvements for the year, but my biz better pickup or...........
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #1049 of 3274 Old 03-18-2009
artbyjody's Avatar
G, thanks for the perspective - gotta say, less the damages - we could of been worse. I am a bit taken aback from the flak I got, and now at a point of possibly losing my boat. Under my command we went from a 40 degree list to less than a 20 when aground...saving the boat - an anchor would of just complicated things as we never didn't move an inch gps wise until VA arrived... the full details are on my blog somewhere in my sig.. The crew and the fact they believed in the boat - all vested their personal lives to seeing her through and she delivered... and that is about the end of the story less what comes of the bill to repair... And yeah - we need not discuss the merits of SA as the types of friends I have made have been here on Sailnet .... Again David, thanks your shorepower cord is back on your boat...
-- Jody
S/V "
post #1050 of 3274 Old 03-19-2009
Wind! Here's wind!
http://
Never Forgotten
bubb2 is offline
luffs, Battens and Leech ? painters Gear & Maintenance 17 11-15-2009 05:56 PM
Sloop or Ketch? maxheadspace Boat Review and Purchase Forum 46 07-27-2007 03:56 PM
Sails on a Boat That I'm Looking At FritzN Gear & Maintenance 9 02-22-2007 12:42 PM
The Balance of Hull and Sails Steve Colgate Buying a Boat Articles 0 05-25-2000 09:00 PM
