09-24-2008
Calling: engineers, physicists, mathematicians-- sail theory
In my 35 years before the helm, my desire for speed has caused me to play around with sail theory. I understand airfoil theory; but I have a big question: an airfoil generates lift because the air on the top of the airfoil must go a greater distance, hence goes faster than the air on the bottom. But the air goes the same distance on the top and bottom of a sail. Moreover, with the angles of attack used in sailing, drag forces are usually greater than lift forces; hence, especially off the wind, Newton's second and third laws of motion(force vectors) are dominant.
This particular inquiry is generated by my discussion in "learning to sail" of the fact that when the leech of the sail is to windward, the lift on that portion of the sail is aft. That is true pursuant to airfoil theory, however if you analyze it from simple force vectors pushing from the windward side of the sail, that is not necessarily true.
Look at the shape of your genoa when you are reaching -- for maximum speed it will have about 90° of curvature. That doesn't work as an airfoil, but it does if you take the integral of the force vectors pushing on the sail.
I have been very successful in racing by using my own "theory of tangents:" your sails are optimally shaped when the luff is tangent to the direction of the wind and the leech is tangent to the direction of the boat; but I would really appreciate it if somebody could answer the questions I have generated above.
p
Reason: spelling
