10-16-2008
Tartan 27' owner
Since you don't seem to be getting much action from the other denizens I will throw my 2 cents at you.
I keep a 19' sailboat on a mooring (50# mushroom) that I deploy and retrieve and I only have to pay $25 a year to the local town for the privilege as a resident of the town (well, my sister is a resident and the boat is technically hers, so this set up is legit). Non-residents pay more for the same privilege (something like $250 and $500 for yacht clubs).
Obviously, with a 33' boat you will need a heavier anchor than I use which will set you back quite a bit, even more if someone else has to deploy and retrieve it.
Have you considered a 'Helix' mooring system? There is a thread on this topic here: http://www.sailnet.com/forums/genera...t-weekend.html
Just out of curiosity, if you are such a cheapskate then where do you keep a 33 footer in the winter?
Good luck.
