10-19-2008
I am assuming you're referring to the catamarans I mentioned. Yes, they're fairly easy to sail, but need to be sailed a bit differently than monohulls.
First, most catamarans are relatively slow to tack and some may need to have the jib/genoa backwinded to come about through the eye of the wind. The catamaran sailors, like CHucklesR and TropicCat can talk about this a bit more.
Second, you generally reef a multihull for peak gust wind speeds, rather than the average wind speeds you'd reef a monohull for. The reason for this is that multihulls can't heel and bleed off the excess wind in the gusts like a monohull can.
Third, you generally want to keep a multihull light... Weight is the enemy of a multihull generally. Also, if you can, keep more of the weight aft in a multihull, since it is generally safer to have a multihull a bit aft heavy rather than bow heavy—since one of the biggest dangers in a cruising multihull is having the bows dig in and the boat pitchpole.
Originally Posted by Polie
I don't know why I didn't think of that myself. After doing a quick search I see that they are in my price range and reviews say that they are very stable. Thanks, now I am going to be up all right looking for at them
Now here is a question, are they as easy to learn how to sail?
