10-28-2008
Termite Fodder
Originally Posted by artbyjody
Is there a tree nearby with a sturdy enough girth or someone with a heavy duty 4WD?
Put the mast back on - then take one of the halyards and tie it off to such. You'll need two people (maybe three)... but put slight tension on the halyard to crank it down on the high side as you use a hydraulic lift under the keel to left it up.
If done in unison - the force on the high side if done slowly from the mast will heel it over as you lift it and the hull should rotate - will allow the hydraulic jack to do its work and you can ease it into position...
Do at extreme risk to yourself, property, and onlookers... Problem with just jacking it at the keel is the trailer is going to have friction and want to go up with it......
Jody, you're a redneck!!
It's an interesting idea, but if you don't snap either the keel or the mast (whichever is the weakest) first by doing this, the second the boat moves on the benches, the keel jack will tip over sideways and the whole boat come down again in kind of a hurry.
I've seen people "bounce" a boat straight by getting a couple of guys to put their backs against the hull on the off side and heave up in repeated bursts, causing the boat to lift partially off the trailer after a few heaves - but that's kind of redneck too!
I suppose it would help if the OP could post some photos of his set-up...
Crew member on the Womboat for:
2011 Heaven Can Wait 24Hr - Race against Cancer.
