10-28-2008
I hope you got it surveyed... a good survey would give you a pretty good idea of what you need to do and what order you need to do it in. Getting an old, neglected boat without a survey is probably a really big mistake, since there can be a lot of hidden and costly repairs the boat needs that you, as a relative novice boat owner, will not recognize off hand.
BTW, epoxy can do a lot of good, but only if you know how to properly use it. It isn't all that good if the underlying structure that you're putting it on isn't sound to begin with.
