10-28-2008
AllThumbs-
StaSet, 5/16", what ever colors you want.  You don't want nylon rope for your running or standing rigging, you want a polyester double braid at a minimum. Anything thinner than 5/16" is going to be hard on the hands... you could possibly go 3/8" but you'd need to check the sheaves on the mast to make sure it can handle the thicker line.
If you want relatively low stretch halyards at a good price, get Sta-SetX, which is a parallel polyester core, polyester cover rope with much lower stretch than a double braid and a bit better strength. Don't use it for sheets, since it sucks for sheets, as it is too stiff.
